doing clutch install...have question.
  • Thread starter Thread starter jmd2914
  • Start date Start date Nov 23, 2005
J
jmd2914
937
Napa, California
Nov 23, 2005
  • Nov 23, 2005
alright, i have all my sensors disconnected, tranny fluid drained, drive shaft out, x pipe and crossmember out, my question is, do i have to disconnect my clutch cable before i drop the tranny? ( i know its a dumb question but this is my first install)
timewarped1972
642
mesa, az
Nov 23, 2005
  • Nov 23, 2005
well you will when you get to the bell housing part, but just to pull the tranny out of the bell housing i don't think you have too, but i could be wrong.....
J
jmd2914
937
Napa, California
Nov 23, 2005
  • Nov 23, 2005
so i have to unbolt the tranny from the bellhousing, pull it out, then unbolt the bellhousing from the back of the motor?
timewarped1972
642
mesa, az
Nov 23, 2005
  • Nov 23, 2005
yeah thats the easiest way to do it........4 bolts, wiggle it out......a floor jack might help..depends on how strong you are.the tranny weighs about 75 pounds.....
as for the clutch cable like i said i'm not sure, the only reason you'd have to remove it is if it has some pre load on the throw out bearing that slides over the bearing retainer which may make it a little stiffer to pull out........ but yeah if everythings disconnected remove the 4 bolts and it should come out...
conartist
77
Windsor, Ontario, Canada
Nov 23, 2005
  • Nov 23, 2005
I would remove the clutch cable now. Before the tranny is out, but it really doesn't matter, take it off now and the clutch fork won't snap back when it comes off the bearing retainer.
My tip for when your installing the tranny is to use two zip-ties tied together to hold the clutch fork to the bell housing cable guide. Makes it a ton easier to line it up with the input shaft...hope that makes sense.
M
Mark89coupe
206
  • Nov 23, 2005
Once you get the tranny out youll understand and installation should be easier.
HISSIN50
34
129
Nov 23, 2005
  • Nov 23, 2005
For more info, see 5 spd gt's write-up and Jrichker's write up. They sometimes post them both on the same thread.
Good luck.
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
