doing some math or rocker arms ???
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
doing some math on rocker arms ???
can you run 1.7rr with Ecam or trickflow stage one ? with e cam you should be about .530 lift range on intake and exhaust ?? and with trickflow intake would be about .531 lift and exhaust would be .542 range ??? will either one have piston to valve clearance problems ????
Kinda hard to say since we don't know the head gasket thickness, which heads, etc. Probably won't be a problem, but don't just look at max lift, since that will be when the piston is on its way down. The real concern is duration, which the E-cam has some pretty interesting valve events
Best way is to pull the head off and put some clay and put it through cycle and see if it clears. Contact Michael Yount on here, or search the Corral for similiar posts, he helped me out A LOT on my build when I did the E-cam
Eric
well my friend has a E cam and he wants to put on 1.7s , his brother has a trickflow stage one cam ?? the question is should they both by 1.7s or one buy 1.7s and the other buy the 1.6s and they both swap and put 1.6s on the intake side and 1.7s in the exhaust side .....???
