Dome light/alarm issues
03stalker
15
Quakertown, PA
I have been having a problem happening off and on for the last month. My dome light will remain on for an extended period of time. All of my doors and my trunk are closed. Becuase of this, my alarm will not arm automatically or go off if a door is forced open. It will "fix" itself after it has been sitting for a while.
I checked the fuse and everything seems ok. I believe there is a relay that keeps the dome light on for 10 seconds or so, or until the key is turned into the on position, after the door is opened and closed when entering the car.
Does anyone know:
1. Is there actually a relay that does this
2. If so, where this relay is
3. If anyone has had a similar problem or may know what my problem is?
Thanks in advance
there is a small pin switch on the inside of the door latches, they come packed in grease, when the weather changes the grease gets hard and wont allow the pin in the switch to release. you can goto a dealer and get an improved version or remove and clean yours.
another thing...
can someone verify that their dome light in their 2003 mustang does infact stay on after closing the door when entering your vehicle. Or Am i crazy and this is a function that was added when i got my alarm, and the alarm needs to be replaced.
