  • SN95 4.6L Mustang Tech
Dome Light Problem
  • Thread starter Thread starter Isaac-1
  • Start date Start date Feb 29, 2004
I
Isaac-1
824
SW Louisiana
Feb 29, 2004
  • Feb 29, 2004
Earlier today I opened the drivers side door while the engine was running, ran into the house for a minute, then back out to the car, since then I have not been able to get the dome light to go off. I have opened and closed both doors several times, and even drove the car for about 20 minutes. For now I have pulled the fuse, but that is only a temporary fix, does anyone have any thoughts on what else to try? It is my understanding that newer mustangs don't have the traditional style door switches for interior lights, instead they just send an open or closed signal to the computer.
Ike
2k3gt
103
York, ME
Feb 29, 2004
  • Feb 29, 2004
Ike
the headlight knob also doubles as controller for the brightness of the interior lighting and the "dome light" on/off switch. maybe when you jumped out of your car you nicked it into the on position... try turning the headlight knob either to the right or the left a bit. that should fix it, i think.
I
Isaac-1
824
SW Louisiana
Feb 29, 2004
  • Feb 29, 2004
I already thought of that, no such luck
ZIPP0
781
Philadelphia
Feb 29, 2004
  • Feb 29, 2004
Slam the door really hard
R
RacerGT
2,371
St. Charles, Missouri
Feb 29, 2004
  • Feb 29, 2004
That's what I did. It worked... now it's back. You need to get a new pin-switch for your door. It's a real pain in the ass. I just took the domelight out. You still have two other lights up there, but they're manual.
forpit2000gt
2,490
Columbia, SC
Feb 29, 2004
  • Feb 29, 2004
the switches are in the door latch itself and are APITA to replace. The dome light is also controlled by the GEM.The GEM is located beside the fuse panel under the dash , it has three plugs in the bottom and two on the back.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Feb 29, 2004
  • Feb 29, 2004
Try this...worked on my Expedition. Spray some WD40 in the door latches. Those switches stick sometimes and a little lube will free them up. Guys on the F150 forums told me about this one.
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Mar 1, 2004
  • Mar 1, 2004
are you certain that it's the door switch? It happened to me once and my dad just grab the headlight knob and played with it for 2 seconds and fixed it..
R
RacerGT
2,371
Mar 1, 2004
  • Mar 1, 2004
Try to lock your doors with your key remote and double click the lock button. If the switch is faulty, your horn will honk twice. It's basically saying you have a door open. Even tho you don't in this case...
GOLDENPONY
1,503
LOVELAND, OHIO
Mar 1, 2004
#10
  • Mar 1, 2004
  • #10
Dome Light
It's called a "Pin Switch"
I
Isaac-1
824
SW Louisiana
Mar 1, 2004
#11
  • Mar 1, 2004
  • #11
Double clicking the remote lock gives me two quick horn beeps, so I guess it means that it is the switch. So how do I change it?
Thanks Ike
V
vld
132
#12
  • Jul 4, 2006
  • #12
i had this same problem with my 03gt. it eventually stopped. now i have no iterior lights because the fuse keeps blowing and i have the double beep from the horn. where exactly do i spray the wd40?
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 4, 2006
#13
  • Jul 4, 2006
  • #13
Sounds like yours is a short if the fuse keeps blowing. Might have a crimped wire somewhere.
spdfrkaby
82
Minot, North Dakota
Jul 6, 2006
#14
  • Jul 6, 2006
  • #14
Before anything spray WD40 inside your door where it latches and get a flat tip screwdriver and use it to lock unlock the latch a few times to work the WD40 in. Happened on my last mustang and it was a 2 minute fix.
N
NPIGT
96
#15
  • Jul 6, 2006
  • #15
wd40 worked for me!
V
vld
132
#16
  • Jun 5, 2007
  • #16
It has now been almost a year and I have yet to be able to get this gremlin. The only symptoms I had that I noticed before this started was one instance of the interior light not shutting off and a seperate instance of the double beep when locking the doors with the remote. Only one time for both of those. Here is the problem as it is now:
The #7 15 amp fuse blows the instant it makes contact. This is with the key off and out of the ignition, the door closed and no acc. plugged in. The #7 fuse controls GEM and interior lights. I have removed every bulb that I can that I know is asst. with that fuse: dome, map, trunk and it still blows. I get a single beep when I lock the doors so I am inclined to think that it is not the latch.
What is drawing power when the doors are closed and there is no key in the ignition?
Can I try a 25 amp fuse?
V
vld
132
#17
  • Jun 5, 2007
  • #17
BTW I have only been able to find one google reference to this problem, here http://www.iatn.net/techmail/summaries/2006/10/17/ midways down titled "2001 Ford Pickup 5.4L gem". Problem is this is a pay site. not fun.
GOLDENPONY
1,503
LOVELAND, OHIO
Jun 5, 2007
#18
  • Jun 5, 2007
  • #18
Electrical bug
You need to find the problem-I wouldn't put a larger fuse in. As they say, once you let the smoke out-you can't put it back in.
J
67 mustang interior courtesy light wiring
  • JCuster
  • Jun 9, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
GypsyR
G
W
Interior and Upholstery New Member auto dimming mirror install issue
  • WigSnatcher92
  • Aug 25, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2025
Mustang5L5
Y
2004 Roush - Dome Lights and radio not working
  • Yurei
  • Nov 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 20, 2025
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Saturday at 5:19 PM
manicmechanic007
L
Electrical issue
  • Landonf00
  • Aug 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 10, 2025
Landonf00
L
