got a few Q's. I have the March u/d pullies minus Alt. pully.
Crank is 4 1/2 inch
water pump is 5 1/2
The March Alt. pully broke long ago(it was TINY) it was on a 100 amp(oem replacment) Now i have the SN95 Alt. with a 2 1/2 pully that came w/ it.
MY MAIN Q IS -- i want to change the Alt. pully for more juice, what would work to get more amps. And i would like the water pump to move more water would the 93Cobra pully work better than the U/D pully and what is the size(or what size would work)
Not to worried about the Crank unless i should be, cause i can change that too if needed.
Crank is 4 1/2 inch
water pump is 5 1/2
im not sure if they fit but i know that if you use a smaller pullie it will make less jucie for the alt and same for the water pump if you go to stock tough you will lose the hp you gained from the pullies smaller
