  • SN95 V6 Mustang Tech
Door ajar light not working
  • Thread starter Thread starter hhspaladin
  • Start date Start date Jul 25, 2010
H
hhspaladin
  • Jul 25, 2010
Hello all, I'm having an issue with my 2004 V6. None of the things that usually happen when the doors are opened are working. The dome light doesn't come on except when the doors are unlocked, and the door ajar light and keyminder don't come on when the doors are open. I know this model mustang has the door ajar switch built into the door and latch, but both can't be out at the same time, right? Any help on this issue would be greatly appreciated! Thank you!
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 25, 2010
  • Jul 25, 2010
Note, your MY Mustang has only a single door switch (for each side). The door ajar switch goes to the generic electronic module (GEM). It is the GEM that decides what to do.
I assume that the dome light comes on when the doors are unlocked with the remote FOB. This confirms that the fuse and the dome light circuit is working.
However, since there is only a single door ajar switch that controls all door ajar functions, IMO it is possible that the door ajar switch is bad and is the source of the problems.
H
hhspaladin
  • Jul 28, 2010
That was my question. Because the dome light does work when the doors are remote unlocked, yet the door ajar light/dome light don't come on when either door is open, does that mean that both door ajar switches are bad?
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 28, 2010
  • Jul 28, 2010
If you don't think both door switches could go bad at the same time (which is not a far fetched idea), then let's look at the other possibilities.
The wiring diagram indicates that both door switches are grounded in different spots. So that's not it.
The GEM itself is grounded at G204 which is the same ground that the radio uses. It is located near the center console (left of the hump).
So any recent radio work? Check the grounds just to be sure.
If it is not a bad GEM ground then it is likely to be a bad GEM module.
To double check, try grounding GEM pin 13 (YE/BK). This should simulate the door ajar switch. If the key minder still doesn't work, then it has to be a bad GEM.
cruisinV6
240
SE Minnesota
Jul 28, 2010
  • Jul 28, 2010
I have a similar problem and I think my door ajar switch is faulty. Where is the switch located so I could replace it?
H
hhspaladin
  • Jul 29, 2010
I just can't believe that I would have bad enough luck to have both switches go out. But then again I have horrible luck, so who knows :/. Unless radio work was done before I got the car, there has been none. It still has the factory Mach audio system and that's been in place for at least a year.
Assuming I'd like to test the GEM pin you mentioned, how would I go about that? Where is the GEM itself located?
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 30, 2010
  • Jul 30, 2010
The door ajar switch is located INSIDE the door. I believe it is located near the latch. I personally have never seen it.
The GEM is located in slightly different locations depending upon model year. It's well up under the dash. Start by looking to the right of the steering column.
R
Door Ajar issue
  • ryjack70ss
  • Jul 25, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jul 25, 2025
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
W
Interior and Upholstery New Member auto dimming mirror install issue
  • WigSnatcher92
  • Aug 25, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2025
Mustang5L5
L
Electrical issue
  • Landonf00
  • Aug 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 10, 2025
Landonf00
L
Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
2000ElectricGreen
