Door hinge pin replacement?
94-302-vert said:
I thought on the 94-95 we had to change the whole hinge not jsut the pins? I found this on the advance auto site:
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=RNB&mfrpartnumber=38395&parttype=713&ptset=A
Anyone done this? is it worth the extra $$ to change the whole hinge vs the aggravation to do just pins?
Chris
In fact... what issue are you having with your hinges...? My drivers door pops.. Loud POP!.. when it gets cold enough. I always thought that the roller in the hinge needs replacing, and was going to replace the whole hinge this fall.
Chris
Those are for a fox mustang, they are different. I got them to work in mine, but it was a PITA and I had to remove the whole upper hinge assembly anyways. I couldn't figure out how to remove the lower....Sometime when I feel ambitious Im gonna replace the hinges the right way because my door still sags a little.
