Door Hinge Pins
  • Thread starter Thread starter lucky bagels
  • Start date Start date Feb 8, 2008
L
lucky bagels
  • Feb 8, 2008
Just wondering if there is a hinge pin better then all the rest, or are they all the same?
1989 LX 302
Thanks
LiquidGT
368
Near STL hell
Feb 8, 2008
  • Feb 8, 2008
50resto, AutoZone, they're all the same from what I seen.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Feb 8, 2008
  • Feb 8, 2008
Buy it at the auto parts store. I did my doors for less than what 50resto wants for their rip off kit. Plus, I got them in 5 minutes, not 5 days, and I didn't have to pay for shipping...
LiquidGT
368
Near STL hell
Feb 8, 2008
  • Feb 8, 2008
L
lucky bagels
  • Feb 8, 2008
thanks guys, i'm off to auto-zone.
Fuzion
81
Virginia
Feb 8, 2008
  • Feb 8, 2008
anybody know of a "How-to" article for this project? thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 8, 2008
  • Feb 8, 2008
Hinge pin & bushing kits are available at many auto parts stores. Or see http://www.texasmustang.com/ or http://www.mustang-unl.com/. Usually less than $8 for the kit with one pin & 2 bushings.
The hard part is to get the old pin out. Some were spot welded in, others were hammered so that the end mushroomed. Either way, it takes a grinder or cutter bit in a drill or Dremel tool to cut the pin or grind off the weld. Once it is off, tap the pin out with a hammer. Only remove one pin at a time so that you don't have the full weight of the door to manage. I highly recommend that you have a helper standing by to hold the door.
Once the old pin is out, lower the door and tap out the old bushings. Put the new bushings in and have the helper lift the door in place so that you can slide the new pin in. It may have to go in differently from the way it came out. That's OK, as long as you put the cotter pin in the hinge pin.
OOOPS!!! The important thing to remember is that the hinge pin isn't supposed to move once you are finished. If it does, then you will end up like me - the pin moved, it wore the door hinge instead of the replaceable bushings. Now in order to fix it right, I have to remove the whole thing again and drill out the hinge to the same size as the bushing and use 2 sets of bushings in each hinge rather than one set.
The fix for the OOOPS was very time consuming and if you aren't up to some very interesting machine work, do it right so you won't have to do it again. I fixed the OOOPS but I had $43 worth of drill bit and specialized reamer plus pulling the fender off to fix it.
Hinge Roller repair kit
  • Rdub6
  • Aug 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 5, 2026
gkomo
R
85 T-Top doors hard to close... Just how it is?
  • rwordenjr
  • Dec 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 7, 2024
rwordenjr
R
Paint and Body Door Sag Help...
  • robw13
  • May 1, 2025
Fox 5.0 Mustang Tech May 8, 2025
robw13
1989 gt both doors wont lock or unlock help.
  • 1989 mustang gt
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 22, 2025
manicmechanic007
C
Fox 1993 LX 2.3 help identifying this
  • Coyoteswap93
  • Jul 17, 2026
AeroCoupe
