Door Latch Questions (Need help ASAP) Please
  • Thread starter Thread starter MysteryMachine
  • Start date Start date May 12, 2006
MysteryMachine
1,835
Parkesburg, PA
May 12, 2006
  • May 12, 2006
Ok working on my 66 the doors have locking issues. The pass door you have to lock from the inside and the drivers door never locks. I bought a latch on ebay a while back and was trying to put it in but its a little different then the old one. It has the other part there ya see in the pic do I need that? Also can i get the little plastic thing at a parts place that holds the rods on its missing the one for the lock pin
Thanks guys
silverbluebp
119
  • May 12, 2006
Most of the parts houses sell the bushing that you're looking for. I replaced both of my latches and found them.
That was a couple years ago!
MustangMatt1966
1,004
Orlando Fl.
May 12, 2006
  • May 12, 2006
My locks also have to be done from inside the car with the door shut, if you try and lock it and shut the door, it runs the risk of breaking the lock for me..i dony know y this is, but it is how it has been since i got the car so i am used to it. So I am sad to say I can not be as much help for this part.
As for the clip: here ya go
http://store.cal-mustang.com/cm_abl...S_ID=4&Product_ID=5048&DID=7&CATID=26&CM_SA=0
MysteryMachine
1,835
Parkesburg, PA
May 12, 2006
  • May 12, 2006
thanks guys! go teh new latch in had to use that old plastic thing which I need to replace cause teh rod falls out of it. Lock works now but the key don't so I have to get new locks I guess
Tim65GT
1,149
West Texas
May 12, 2006
  • May 12, 2006
This Thread has a lot of info and pics:
http://forums.stangnet.com/showthread.php?t=612696
19stang66
689
  • May 13, 2006
I thought you would post that tim. That thread helped me a ton. I had the exact same problem you had. These are the plastic things you need View attachment 470241. Not the ones previously linked to.
Heres the link to the ones you need http://www.mustangsunlimited.com/ite...sp?T1=F1306+01.
MysteryMachine
1,835
Parkesburg, PA
May 13, 2006
  • May 13, 2006
Tim65GT said:
Originally posted by speedytang:
I was talking about the window track not the stainless piece that wraps around the window.
Anyway I got a couple pics of the latch fix and rod configuration.
Here is the lock motor I modified to fit from a 82 Thunderbird. I used an existing hole in the lock lever.
I started to put the door and hinges back on, but it looks like the only way to get it aligned right is to take the fender off.
Ok in that pic you have the lock bar going all the way down mine was attached at that black plastic thing with the washers. Were is it actually suppose to go?
MysteryMachine
1,835
Parkesburg, PA
May 13, 2006
  • May 13, 2006
oh wait never mind you have a rod from the cylinder it looks like there is that right?
Tim65GT
1,149
West Texas
May 16, 2006
  • May 16, 2006
Yes, all the rods are in place in that picture.
When you get your bushing kit, this picture helps explain where everything goes:
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
P
Fox Opinions Wanted- at a crossroad with my '88 GT
  • pindude80
  • Apr 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 22, 2025
pindude80
P
