DOOR LOCK ACTUATORS..
  • Thread starter Thread starter THC420
  • Start date Start date Mar 10, 2004
T
THC420
Banned
Dec 18, 2001
202
Ontario, Canada
Mar 10, 2004
  • Mar 10, 2004
does anyone have a diagram as to where i install the top hook piece of the door lock actuator into? i just picked up some new OE actuators from 50 resto, but cannot for the life of me figure out where that thing hooks into..
any help would be greatly appreciated.. thanx
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 10, 2004
  • Mar 10, 2004
It's a littl late to save you some $$$, but maybe the pictures will help...
Follow this link to fix your door lock actuator problems http://jrichker.stangnet.com/Mustang_tech/door_actuator_fix/1_of_8_door_actuator.htm
Stuck with door lock actuators that don't work and don't want to pay the $50+ for a new one? Tried the junkyard ones and found that they last six months and freeze up?
A new actuator for less than $4. Fix one side for $17, do both sides for only $23. I don't sell parts, I don’t make any money off of the upgrade, I just tell you how to do it cheaply and easily.
H
Highbredcloud
1,075
Palos Hills, IL
Mar 10, 2004
  • Mar 10, 2004
jrichker: hmm...how hard is that to do? it does sound tempting to try...
HISSIN50
34
129
Mar 11, 2004
  • Mar 11, 2004
i will let Jrichker speak for himself, but i will add what i can.
Highbredcloud, i did his retrofit. piece of cake. i am very glad i did it. i will do it on the other door when it poops out. very nice write up. cant ask for much more detail than what is offered. his design will long outlast the car. LOL.
THC, the actuator hooks into the lock linkage assembly. Duh. i am too lazy to look at the write up (dial up), but i think he covers it. if not, move the manual lock (on top of the door panel) and see if the linkage moves. it goes into the moving part. there is a hole near the bottom of the assembly. or take the other door's panel off and check it out. as i said, Jrichker's pics were great and i think he has a pic of it. i mentioned that just in case. good luck.
R
RacinChris
274
Gainesville, FL
Mar 17, 2004
  • Mar 17, 2004
I can't move the manual lock on either of my doors. And the passenger door's manual lock is stuck in the lock position now, so I can't open the door at all. This is not good. Will replacing the actuators fix my problem, or is there something more wrong? And how am I going to get the passenger door open?
K.C.90gt
379
Detroit Area, MI
Mar 17, 2004
  • Mar 17, 2004
when you say manual locks do you mean you dont have a lock/unlock button for power locks? because if you have actuators then they are power locks. Anyway if you do have power locks then I can offer some help.
This happened on my 93 ford tempo, it uses the same door lock actuators. My door would not lock, it was stuck in the unlock position and with the key or pushing on it it wouldnt budge, All I did was take off the door panel and remove the actuator, it was all bent and wouldn't move so thats why. Remove your actuator and it should lock/unlock freely.
shallto
464
OBX, NC
Mar 17, 2004
  • Mar 17, 2004
I did that retrofit. I did it a little different though. I sniped off the ends of the original actuatos as far down as I could. Then I drilled a hole in the top of the new one. I then slid the old tip into new actuator. The old actuator tip has a groove that is perfect for a c-clip so thats what I used. I then took a pair of pliers and flattened the new actuator connectors and they slid into the connectors perfectly. I used the screws that came with the actuators to secure them in the rubber gramet that held the old one. Its a lot easier than it sounds.
R
RacinChris
274
Gainesville, FL
Mar 17, 2004
  • Mar 17, 2004
I do have lock/unlock buttons for the power locks, but pressing them does nothing of course. Cool, that's good to hear that removing the actuators fixed the problem. And while the door panel is off anyways, I might as well try jrichker's door actuator retrofit. Will I be able to remove the passenger door panel and remove the actuator with the door stuck closed?
K.C.90gt
379
Detroit Area, MI
Mar 17, 2004
  • Mar 17, 2004
yea, you should be able to remove the panel with the door closed. my lock button didn't work at one point and I took the cover off of the lock buttons and sprayed some wd-40 underneath the button by the trigger and worked it back and forth and it cleaned the contacts and started working, so maybe u could try that too. Just for the heck of it, did you ever try pulling on the door handle to see if it opens then? because my passenger side door lock is screwed up too and the only way I can open it is to pull the door handle, pulling up on the lock knob doesnt work.
R
RacinChris
274
Gainesville, FL
Mar 17, 2004
#10
  • Mar 17, 2004
  • #10
Yeah, I've tried pulling the door handle... it feels like it'll break off before it ever opens the door, lol. That wouldn't be good, either. As for cleaning the lock buttons with wd-40, is that even a possibility with my locks not being able to move? It seems as if the actuators are bent, like they were in your Ford Tempo, and that's why they won't move.
K.C.90gt
379
Detroit Area, MI
Mar 17, 2004
#11
  • Mar 17, 2004
  • #11
well if the button works on the drivers door or if you hear it activating the actuators than no it wont do nothing because the button works, I didn't know if your button works or not but I was just giving some more possibilities of what it could be. But more than likely its a frozen actuator if you can't move it.
SCORPION
386
Seaford, DE
Mar 17, 2004
#12
  • Mar 17, 2004
  • #12
can someone send me the text....i can't get the page up.
R
RacinChris
274
Gainesville, FL
Mar 17, 2004
#13
  • Mar 17, 2004
  • #13
I'm not sure if the button works or not, either. A guy at Pep Boys told me to check the fuse box, and I checked it for a possible fuse that might control the locks, but didn't see one. Should it be making a sound when I press the button, even if both actuators are frozen?
K.C.90gt
379
Detroit Area, MI
Mar 17, 2004
#14
  • Mar 17, 2004
  • #14
When you push the unlock or lock button it should make some sort of noise if the button is working correctly. Either way you still should be able to unlock the door with the key or pulling on the inside door handle. If the button doesn't work than it could be dirty contacts or a fuse or a wiring problem.
R
RacinChris
274
Gainesville, FL
Mar 17, 2004
#15
  • Mar 17, 2004
  • #15
Oh ok, then I have more problems than I originally thought. Well, I'll double check, but I'm pretty sure that it doesn't make any noise when I press the button.
91notch5.0
623
warren mi
Mar 17, 2004
#16
  • Mar 17, 2004
  • #16
GET THE UPGRADE!!!!!
i have them and it is a completely different design and workes great DO IT.
now we just need some good door handles....
HISSIN50
34
129
Mar 18, 2004
#17
  • Mar 18, 2004
  • #17
i did not read all the new posts, so if i duplicate something, i apologize. if your locks wont lock or unlock when you try to move the manual knob on the door, then the actuators are frozen. you may have other electrical issues, but the actuators seem frozen.
the linkage on the knob goes to the lock but via a different means than the actuator. if you can cut the rod on the actuator, the manual lock should work. a pair of wire cutters work if you have a little strength. the actuator is frozen, which freezes the linkage and whole lock mechanism (slides up and down), so the knob does not work.
this is all what i recall and what seems logical, but i have not had to do it, so dont yell at me if i am wrong (have not had a frozen actuator). sounds good to me, though. LOL.
R
RacinChris
274
Gainesville, FL
Mar 18, 2004
#18
  • Mar 18, 2004
  • #18
Cool, thanks for the info, that helps out a ton. I guess I better order those actuators soon, and buy any other parts I'll need.
HISSIN50
34
129
Mar 18, 2004
#19
  • Mar 18, 2004
  • #19
you should be able to cut the little rods on the actuator (where they leave the actuator body) and use the locks manually.
other parts you will need (other than what Jrichker lists for the actual retrofit): new door clips (secure the inner door panel). i dont order them. i am tired of them not working more than a few times, so i use a few small sheet metal screws (use small headed ones and paint the heads, and stick them in the carpeted part of the inner door panel and no one sees them). just what i do.
there are some kits that include the door clips if you order 2 ford style actuators. i would do Jrichker's retrofit instead. not nearly as hard as the write up sounds. good luck. i am sure you will be happy with it (and future 4 dollar replacements if needed).
blk92stangg
583
Hawaii
Mar 18, 2004
#20
  • Mar 18, 2004
  • #20
I found good substitute panel clips from the local hardware store for fiddy-cents apiece. Its made from a white plastic that seems more robust than the stock ones, but we will see if they last any longer than the stock ones.
Electrical Are there any aftermarket door lock actuators that actually work?
  • 89notchDude
  • Nov 24, 2024
3K
Fox 5.0 Mustang Tech Dec 2, 2024
FastDriver
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Interior and Upholstery Best vinyl adhesive for door panels?
  • wobbyguy
  • Jan 27, 2025
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 31, 2025
limp
R
Console lighting
  • rde1068
  • Sep 1, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 6, 2025
rde1068
R
