Door lock actuators...
808Gt
115
Hawaii
K my problem is I bought universal door lock actuators and did the door lock retro/fix that was on this site... did everything and worked for awhile, But the motors got burnt and stoped working...
If anyone has done the door lock fix with universal door locks, can you tell me what am I doing wrong and why it is burnning up the motors??
What do you mean about the motors getting burned up? I had very good luck following JRichker's write-up.
The wiring is super simple as I recall. Did you do anything weird?
More info please.
Good luck.
yea it was easy to install...
dunno, I put an alarm in the fox before the door locks, its a viper 5900 sst.... I had to use relays to inver the polarity of the door locks since the alarms wire is a (-)
Did you get the relay wiring correct? If connected incorrectly it can wipe out an actuator (I've seen Motormites get wiped out at least). Stangs without keyless use reverse polarity wiring.
808Gt said:
ok, I checked the wires for the locks with a meter and it shows, unlocked 6 volts then to 0 volts, but when pressed lock its at 26-28 volts constant:shrug: ??
This was tested at the two wires going to the actuator? I'd go backwards and take a reading at your SPDT relays (or DEI 451M if applicable) and see what's coming out of the common relay terminal.
I cant imagine how you're seeing that kind of actual voltage, but something is wrong and we can see how it could wipe out an actuator.
Maybe one of the installers/wiring gurus on here will chime in with some thoughts.
Ok, just re-checked again... its 12.7 locked constant and 6.8 unlocked then to zero...
What i dont get is why is it constant voltage when lock? shouldnt it go down to zero??
WHen you hit lock, the actuator doesnt let up? You're right about that - it should pulse (show 12 volts for a second or so) and release (you can see the lock knob go up a little bit when it releases).
If it's staying at constant 12 volts while the doors are locked, that would sure fry actuators quickly. I'm not sure what would cause the the lock pulse to latch like that though, unless your external relay is latching.
Normal alarm door lock wiring: The N.O terminal provides power to the common terminal when using the key fob.
WHen you use the lock button in the car, the N.C terminal and common terminal are closed, so the pathway requires no input from the relay.
Does your actuator show 12 volts after hitting the arm button, and also after using the lock button in the car?
If one or the other, it gives a direction to look (for the former, check the lock relay. For the latter, check the lock switch in the car).
I'm just thinkin aloud here. How's that sound?
yea, I checked everything again including relays and all...
the meter now shows about 12 volts lock, 12volts unlock... looks to be alright for now but will see....
im an electrican, and that sound funny to me.. somthings deff, wrong when your getting 12volts consistant... make sure wires arnt crossed, and you line in and load out are correct... i dont have one of these nor no what your talking about but it has to be somthing along these lines.. maybe a short in a wire...
*** since i dont know to much about what it is your doing, im not gonna post to many times in here and make myself look dumb, i am an electricion for buildings and houses... but this isnt maken any sence to me... so im gonna lay low and read more post, ill pop in when i think i found the problem as the post continue on.. ! ***
it seems to be fine for now though, ummmm it shows 12volts or so maybe less when un-locked with alarm remote...
When locked with remote it shows 12 volts or awhile then goes back to 0 volts...
If something is hanging up (and is still latched), now is a good time to find it.
It's tough to offer much advice from a keyboard though.
Good luck.
K, I have found out what my problem was about the door locks...
My alarm was the problem, I guess I activated a feature called "comfort closure" it supply a 20 second pulse on the lock/unlock wire 200 milliseconds after you lock or unlock. This triggers the factory automatic windows, in new cars like the 06 mustang etc. with one touch windows...
but yea thanks for all your help....
off to buy new locks.... :-)
Glad to hear you got it whipped. Of the alarm installs I've done, all required an add-on window module. Your alarm must be a nice one. :nice: Honestly, I didn't consider that you could have a window pulse holding the locks.
Glad to hear you got it. :nice:
If I didnt mention it before, the JRichker window retrofit is super simple and easy. And the actuators sound a lot more 'solid' IMHO than the stockers.
Good luck.
