door lock problem
  • Thread starter Thread starter 92 LX
  • Start date Start date Apr 2, 2008
9
92 LX
78
  • Apr 2, 2008
Guys,
I've got a '92. The pass door lock outside failed a while ago, (key won't turn). Now, the pwr lock won't unlock the door, and the inside handle won't unlock/open the door either. When I pull on the inside handle, the lock button raises just a hair but that's it. I can't get the d*** door open. Something's gotta be jammed. The pwr window works. If I can get a slim jim, is the lock rod on the inside of the glass or the outside. I seem to remember it's on the inside. Have any of you guys experienced this prob. before? Any ideas? The Actuator?
Thanks,
Greg
(Grateful it's not the driver's door!)
J
Jmunk
95
  • Apr 2, 2008
Sounds like you need a new lock actuator, I needed one and get a "kit" off ebay for like $9 I think not too long ago.
bloopbloob
578
Alberta
Apr 2, 2008
  • Apr 2, 2008
the lock rod is inside the glass (between window and interior)
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 2, 2008
  • Apr 2, 2008
Follow this link to fix your door lock actuator problems http://bellsouthpwp.net/l/r/lrichker/Mustang_tech/door_actuator_fix/1_of_8_door_actuator.htm
Stuck with door lock actuators that don't work and don't want to pay the $50+ for a new one? Tried the junkyard ones and found that they last six months and freeze up?
A new actuator for less than $5. Fix one side for $18, do both sides for only $25. I don't sell parts, I don’t make any money off of the upgrade, I just tell you how to do it cheaply and easily.
Here’s a picture of the new actuator installed:
9
92 LX
78
  • Apr 3, 2008
Thanks a lot.
You guys are the best!
O
oldwantabe
11
  • Apr 4, 2008
It is the door lock actuator.I just replaced both on my 93 coupe .It is not hard to do just takes a little time.Get you some more of the pins that hold the door panel on.Got my actuators free from a friend of mine.Ford charges too much for the plastic door snaps or pins.Saw them on Ebay cheaper.
O
oldwantabe
11
  • Apr 4, 2008
Gear shift boot bezel.
How do you remove the square panel around the gear shift boot of a 1993 coupe lx.I think it just snaps in but dont want to break it.I have a pro 50 I want to put in.Shifter no problem,panel scares me.
bloopbloob
578
Alberta
Apr 4, 2008
  • Apr 4, 2008
start a new thread for a new topic please. don't derail someone elses. but yes, it just pops out.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Apr 4, 2008
  • Apr 4, 2008
you would know
bloopbloob
578
Alberta
Apr 4, 2008
#10
  • Apr 4, 2008
  • #10
BK_CAULEY said:
you would know
ha. yup. unfortunately all too well. i've honestly had to take door panels off probably over a dozen times in the last 3 months.....
O
oldwantabe
11
#11
  • Apr 5, 2008
  • #11
I didn't mean to start something different.Never had done anything on here before. The gokart thread I normally am on works a little different.Sorry Blooploob please huh huh forgive me please
BDASPNY
103
HAMPTON ROADS
Mar 21, 2009
#12
  • Mar 21, 2009
  • #12
old thread i know but i have the same problem. the power act went out. the door is stuck locked. the inside handle will not unluck it. the key won't turn. i tried pulling the door lock pin and it came completely off w/ the rod. i tried spraying a lube into the door lock to loosen it that didn help either .so if the key won't turn, the inside handle won't open it what next? so i'm stuck any ideas???/
BDASPNY
103
HAMPTON ROADS
Mar 23, 2009
#13
  • Mar 23, 2009
  • #13
bump
89llx
5 Year Member
Aug 31, 2009
302
Jul 9, 2010
#14
  • Jul 9, 2010
  • #14
remove the seat so you can get the door panell off
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Electrical Are there any aftermarket door lock actuators that actually work?
  • 89notchDude
  • Nov 24, 2024
3K
Fox 5.0 Mustang Tech Dec 2, 2024
FastDriver
1989 Passenger side electric window issue
  • Sanchez_005150
  • Jul 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
R
Electrical OEM Door Lock Actuator Internals/Rebuild?
  • Radau
  • Sep 1, 2023
Fox 5.0 Mustang Tech Sep 1, 2023
Radau
R
