door lock problems
  • Thread starter Thread starter BK_CAULEY
  • Start date Start date Dec 30, 2006
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Dec 30, 2006
  • Dec 30, 2006
the other day i posted a thread asking about a problem with my door locks and was told there was a fuseable link next to my starter solenoid but i cant find it, the problem was they just all of a sudden quit working. one day last week they where working fine at lunch then about an hour later i got i my car hit the switch and nothing happened. the passenger side doesn't work either could someon please give me some advice? i have ckecked all fuses and even cleaned the switches to make sure they were getting good connection but stil have nothing. any advice out there?
superhuaman
907
Harrisburg, PA
Dec 30, 2006
  • Dec 30, 2006
i think on mine the door locks run off the small silver box attached to the starter solenoid on the fenderwell. that little box is a circuit breaker. i know that the power wires under the seats are attached to this. when i pulled the c.b. off to cut poer to those wires, the door locks didnt work. so check that c.b.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 30, 2006
  • Dec 30, 2006
There are no fuse links for the door locks. There is a little tin box on the starter solenoid. It holds the circuit breaker for the power windows and door locks.
You need to use a voltmeter on the connection to the door lock motor to test for voltage. Connect the meter leads to the two sockets instide the connetor shell. You shold see 12 volts across the two wires when you actuate the switch. The switch will apply a different polarity when you change from open to locked. If you use an analog meter, the meter will peg out in the reverse direction on either open or lock.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
Electrical 5.0 88 Foxbody Door Locks
  • 88VertFox
  • Aug 29, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
Mustang5L5
Electrical ’86 Mustang – Power Windows/Locks Dead After Terminator X Swap
  • 5.0 Mike
  • Aug 21, 2025
Fox 5.0 Mustang Tech Aug 21, 2025
5.0 Mike
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
