Fox Door Lock Problems
Mike Amato
Active User
Nov 9, 2016
22
Anyone have this door lock problem? When I hit unlock on drivers side it unlocks drivers side and locks passenger side. If I hit lock on drivers side it locks driver side and unlocks passenger. Vice versa if I hit unlock on passenger it unlocks passenger and locks driver???
Something is switched somewhere.
So if I'm reading it right , both switches work correctly for the door they are on but are reversed for the other door?
If so, that's where I would start, by checking the wires that connect the two
Is it possible somebody replaced a door lock actuator with a wrong part number? For instance, some cars use negative ground system while others use positive ground system. Maybe somehow the wrong actuator got installed? This could make the function of the actuator be the opposite of intended.
I believe that to be true as I see a bolt on the bottom of the door not a rivet
Swap the connection of the wires. Cut the wires near the actuator, strip and re-splice in the opposite position. Problem solved. Avoid cutting the harness in the door. But who cares if you cut a harness plug of a part that can easily be replaced in the future?
Here they are.
Switch pinouts here
