  • 2005 - 2009 Specific Tech
Door speaker setup - 2 PAIR?
  • Thread starter Thread starter red93coupe
  • Start date Start date Oct 26, 2004
R
red93coupe
72
Overland Park, KS
Oct 26, 2004
  • Oct 26, 2004
It looks like the '05's have locations for 2 pairs of door speakers - 1 pair of 6.5" down low in the obvious grille, and possibly a pair of 5x7" woofers directly above and recessed in the door? Can anyone set me straight?
R
red93coupe
72
Overland Park, KS
Oct 29, 2004
  • Oct 29, 2004
I can answer my own question.
Yes, they do. I sat in one for the first time today.
This opens all kinds of possibilities for top-notch front stage with 3-way components.
A
askiles
15
  • Oct 29, 2004
Speaker Setup
The speakers in the front door are:
Stock = 5 1/2" behind grill half way up door, & maybe a tweeter above that. 6" x 9" in rear
Shaker 500 = 5 1/2" Behind grill, 8" Subwoofer in bottom of door
6" x 9" in rear
Shaker 1000 = 5 1/2" Behind grill, 8" Sub in doors, (2) 8" Subs in trunk.
6" x 9" in rear
I believe this is correct, but if not, it's close.
K
KickerStang
593
Colorado Springs
Oct 30, 2004
  • Oct 30, 2004
I wonder how that is going to sound stock and with the after market...
05RIDE
11
  • Nov 3, 2004
The subs in the trunk on the shaker 1000 are tens I will have to look at the rest when it stops raining.I will tell you the 1000 rocks like no other factory radio I have heard!
K
KickerStang
593
Colorado Springs
Nov 4, 2004
  • Nov 4, 2004
Are the subs pretty boomy, or tight sounding? Do they cut out the bass the louder you turn it up? That is the 1 thing I hated about the Mach 460. I wonder if swapping out subs and keeping them in that enclosure will sound better.
05RIDE
11
  • Nov 4, 2004
Kickerstang,They do not appear to cut out as the old 460 sound system did they rock and the bass sound like that of the after market systems.One thing I can't figure out I tried to add my xm radio reciever to the mach 1000 system today and lost part of the power to the radio no sound or radio functions just the clock and cd ejection will work.I even removed everytthing and put it back as before but still no luck gess its back to the deler.I don't think you will be disapointed by the 1000 I have been messing with car stereos for along time and it sounds good to me.
E
Enfynet
43
Cleveland, OH
Nov 11, 2004
  • Nov 11, 2004
6" x 9" in rear
6" x 9" in rear
As far as I know...
Stock
- Door 5x7 (5 1/4" or 5x7 or 6x8 fit)
- Rear 5x7 (5 1/4" or 5x7 or 6x8 fit)
Shaker 500 = Stock +
- Door 8" subwoofer & Component tweeter
Shaker 1000 = Shaker 500 +
- Trunk 2 10" subwoofers
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Nov 21, 2004
  • Nov 21, 2004
I bet that set up is going to sound great!
cray1801
20
Fuquay-Varina, NC
Nov 30, 2004
#10
  • Nov 30, 2004
  • #10
The Shaker 1000 will be a dissappointment to some people. The cost is high over the Shaker 500 and the bass is boomy, not tight and accurate. Listen to both before making the decision. Use your own CD's to test the systems with.
krang00
79
Allentown, PA
Mar 28, 2006
#11
  • Mar 28, 2006
  • #11
How did you guys get access to the rear speakers? How does the cover come up? Also, which wire is + / -? I have some kenwood speakers from my other mustang I want to install.
krang00
79
Allentown, PA
Mar 29, 2006
#12
  • Mar 29, 2006
  • #12
Ok, I'm an idiot. The rear speaker grills just pop off. On the bright side, I came across this sample master sheet from crutchfield, just so happened their sample was for a 2005 mustang. http://akamaipix.crutchfield.com/graphics/download/sample_0190011.pdf
N
nbk13nw
186
Newport News, Va
Mar 30, 2006
#13
  • Mar 30, 2006
  • #13
With the Shaker 500, the door (upper) speakers are using what loks like a 4" mid and a 1" tweeter on a 5x7/6x8 mounting plate. I replaced these with some Rockford Fosgate P1682S Full range 6x8's. As for the door subs, I put in some Rockford Fosgate P18S4 8" subs. A little work to get them to fit, but by using a heat gun I was able to soften up the sub enclosure enough to "mold" the speaker into it just fine.
The rear deck I put another set of Fosgate P1682S Full range 6x8's and for low end I used a pair of Fosgate P110S4 10" subs running off a Fosgate P3001 amp.
The fronts doors (6x8's and subs) are running off of a Fosgate P4004 amp. I also bought 100sqft of Dynamat. So far the trunk, fenderwells and doors have been completed. I still have the floorpan and the tranny tunnel to go. It sounds awesome compared to the stock system. Funny thing is, even with the Alpine head unit (9847) it still cost less than the factory Shaker 1000 system.
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 5:48 PM
from6to8
