Correct me if I am wrong. To install the aluminum rivets in the door tag: place rivets in the two holes in the plate and into the door, remove the door panel, use shank end of a 3/16" drill bit and slightly tap on the rivet from inside the door while a third person holds the rivet in place from the outside until tightened up. Is this right?
