Do's & Don'ts?
  • Thread starter Thread starter crushnut
  • Start date Start date Jan 28, 2004
crushnut
870
Oregon
Jan 28, 2004
  • Jan 28, 2004
With installing a mechanical oil pressure guage, i've already got the copper tubing and stuff. Anything that i should be careful not to do, or watch out for? This is my first mechanical guage install, im use to electrical guages.
Thanks
D
D.Hearne
11,730
south louisiana
Jan 28, 2004
  • Jan 28, 2004
Well, first of all , ditch the copper tubing and use the nylon tubing that comes with the gauge. I like to feed the nylon tubing into vacuum hose to protect it from any possible damage, it also blends it into the scenery under the hood.
bud4660
459
Mesquite, Tx
Jan 28, 2004
  • Jan 28, 2004
Why couldnt you do the same with the copper tubing?? I have had the nylon break at one of the fittings and spray oil everywhere. I also like to use alum tubing over copper.
2bav8
2,511
Mesa, AZ
Jan 28, 2004
  • Jan 28, 2004
Any NHRA drag strip requires copper tubing.
rbohm
6,698
550
204
tucson,az
Jan 28, 2004
  • Jan 28, 2004
coil the copper tube near the firewall to prevent vibration cracking.
crushnut
870
Oregon
Jan 28, 2004
  • Jan 28, 2004
The plastic tubing that came with the guage was crap, it was all coiled up and just trying to straighten it out put kinks and bends in it, so i decided to ditch it and get copper tubing, as recommended by pabear89.
G
gp001
4,401
So. Cal.
Jan 28, 2004
  • Jan 28, 2004
I've always hated mechanical gauges for this reason. We put one in a friends 5.0 and the nylon line broke. Then the copper went at the compression fitting. After 2 very messy breaks I suggested he use some braided line and fittings. He did and has not had a problem since. It's a little pricy, but after the mess it was well worth it. Just another method to think about.
charlies
390
in front of computer
Jan 28, 2004
  • Jan 28, 2004
don't hook the pressure line to the winshield washer nipple at the edge of the back of the hood.
crushnut
870
Oregon
Jan 28, 2004
  • Jan 28, 2004
huh why would you do that?
D
D.Hearne
11,730
south louisiana
Jan 28, 2004
#10
  • Jan 28, 2004
  • #10
In all my years of using nylon tubing, I've never had one break. The only nylon tubing I have had break was the coiled lines running from the truck to trailer on an 18 wheeler, and this was in sub-zero weather. Copper tubing is subject to being kinked, ditto for aluminum. Just because the NHRA requires something doesn't mean it's the best thing to use. The Federal DOT regs, also have rules that require things that are also not the best solution to a problem.
charlies
390
Jan 28, 2004
#11
  • Jan 28, 2004
  • #11
not sure on the why, but the result would be dramatic.
cardude
221
Portland, OR
Jan 28, 2004
#12
  • Jan 28, 2004
  • #12
watch for kinking and such especially under the dash, it gets tight in there if you are trying to make it pretty and tucked away.
68stang351
850
9
39
Savoy TX
Jan 28, 2004
#13
  • Jan 28, 2004
  • #13
After I first put my windsor in my car, I was going down the road ragging the crap out of my car while passing someone. I look back to see a HUGE cloud of white smoke, so thick that I couldn't even see the car I had just passed. I look at my oil gauge and the pressure is at 0.
I thought "Oh great, I just got the new motor broke in and now I tore it up." I pulled over and I was all worried that I had royally screwed my new motor up. I didn't notice anything odd under the hood, so I couldn't figure out what happened. So I decided to see if it would start back up and see what it sounded like. So I start up the car with the hood up and oil goes everywhere. Turns out that the stupid nylon line had a pinhole melted in it and was shooting 60psi of oil onto my headers.
I wasn't smart enough to get copper right away, but I decided to after I burnt 2 more nylon tubes. Yes I tried to keep them away from heat, but I think they melt too easily.
D
D.Hearne
11,730
south louisiana
Jan 28, 2004
#14
  • Jan 28, 2004
  • #14
That's why I suggested running it inside vacuum hose. And I don't route it anywhere close to headers or manifolds.
12sec67
1,301
San Diego, Ca
Jan 28, 2004
#15
  • Jan 28, 2004
  • #15
i had my nylon break on me a few times then goy smart and went to copper.... no problems in 2 years.
but putting inside of another tubing is a good idea
G
GaPonyFarm
663
Columbus, GA
Jan 29, 2004
#16
  • Jan 29, 2004
  • #16
Maybe a dumb question... Why would you want to use a mechanical gauge? Electrical gauges are at least as accurate, if not more so. Just buy good gauges, and sending units, and don't subject yourself to the hassles of mechanical stuff.
D
D.Hearne
11,730
south louisiana
Jan 29, 2004
#17
  • Jan 29, 2004
  • #17
There's just something about Mechanical gauges ( can we have a Tim Allen, aarrggghhh ,aaarrgghhh, aaaarrrgghhh here? ) over electric ones
69 302/351c
1,147
Walkertown NC, originally Western Mass
Jan 29, 2004
#18
  • Jan 29, 2004
  • #18
I went with the braided line on my 302, copper on my 351C. I've seen the nylon lines after a couple of years and it gets hard and brittle. Also have both mech. and elect. gages. Aftermarket mechanical with the stock gages in the instrument cluster still operative.
crushnut
870
Oregon
Jan 29, 2004
#19
  • Jan 29, 2004
  • #19
Exactly
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Jan 29, 2004
#20
  • Jan 29, 2004
  • #20
Thanks
I use the copper tube covered with 1/4 in ID vac hose in the engine compartment area to and thru the firewall.
It will keep the tube safe from caffing and make it a cleaner mounting for clamps.
It's a good idea to wrap a few coils for future work.
U can use a aspirin bottle and wrap the line around it so not to put a kink in the tube. one or two coils at each end will help if you ever need to disconnect or move the tube.
Just my opinion.
PB
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
