  • SN95 4.6L Mustang Tech
Down some power, summertime temps?
  • Thread starter Thread starter spederman
  • Start date Start date Jul 25, 2007
spederman
732
  • Jul 25, 2007
I just upgraded to GI joes 8 rib setup with a 3.2 RR pulley. Previously my setup was the 6 rib w/ 3.25 vortech pulley. I was getting pretty bad belt slip. Now there is none which is sweet. But for some reason i am down quite a bit of power and was wondering if summertime temps/humidity can affect the numbers this much:
6 rib 3.25 vortech pulley @9psi= 400rwhp/403rwtq (dyno'd in march when temps were prolly in the 60-70's here in TX)
8 rib 3.2 RR pulley@9psi= 377rwhp/375rwtq (dyno'd yesterday temp in the high 90's & about 80% humidity)
What do you think, is this normal summertime power loss? or should i look into something with the car?
Tim2002GT
635
Tulsa, Oklahoma
Jul 25, 2007
  • Jul 25, 2007
The temperatures are most likely to blame. That and the high humidity. I have heard of FI cars losing up to 5% hp in the hot summer air.
Stan Weiss
347
Philadelphia, PA
Jul 25, 2007
  • Jul 25, 2007
The temperatures will only be to blame if the numbers are uncorrected. Most times you get corrected numbers. What do the dyno sheets say?
spederman
732
  • Jul 26, 2007
I am getting the dyno sheet emailed to me tomorrow since their printer was broke. I'll take a look and see what other info i can get from the dyno and post them. How do i know if the numbers are corrected or not?
Stan Weiss
347
Philadelphia, PA
Jul 26, 2007
  • Jul 26, 2007
Normally printed on there will be something like "CF 1.03". It should also list the temperature, humidity, and barometric pressure.
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
R
Engine Temp Rising During Normal Driving
  • redneck15431
  • Sep 10, 2016
3K
Fox 5.0 Mustang Tech Sep 13, 2016
Knowbody
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
Engine Asp Pullies Do Cause Overheating Issues
  • FastDriver
  • Jun 1, 2015
3K
Fox 5.0 Mustang Tech Jun 5, 2015
FastDriver
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
