  • 1994 - 1995 Specific Tech
Drag strip ratio (4.10, 3.73?)
  • Thread starter Thread starter Touring23
  • Start date Start date Dec 10, 2008
T
Touring23
294
Washington
Dec 10, 2008
  • Dec 10, 2008
This is for a fully-laden street Cobra with 26.0" tires, 5-speed, and mild mods but no blower or nitrous. If I did the calculations correctly, trapping 100mph would result in either 4800 (3.73) or 5300RPM (4.10) in 4th gear.
3.73 is all ready installed and am curious about going to the 4.10?
Thanks. Searchy no findy. opcorn:
Stopsign32v
394
Gville, SC
Dec 10, 2008
  • Dec 10, 2008
I will be running 4.30s
T
Touring23
294
Washington
Dec 10, 2008
  • Dec 10, 2008
'Kay. Thanks for sharing that.
Stopsign32v
394
Gville, SC
Dec 11, 2008
  • Dec 11, 2008
lol since this is bothering you so bad and you already have the 3.73s in why don't you take your car to the track the next time you get (depending on if the track is still open near you) run your car and then change the gears to 4.10s and run it again. TADA!!!!!!!!!!! There will be your answer!!!!!
However I would focus on other mods. Port your intake, get better heads, etc etc.
vladasap
294
nyc, ny
Dec 11, 2008
  • Dec 11, 2008
4.10s are too steep imo.
i rev to 5400 and the car goes past that at a 1/4 so now im regretting the 4.10s
I'd say stay with the 3.73s, especially if you drive the car regularly like me
Joe 5.0
1,184
Macomb, MI (metro detroit)
Dec 11, 2008
  • Dec 11, 2008
I'd stick with the 373's for now, as you dont have the top end to take advantage of the 4.10's.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Dec 11, 2008
  • Dec 11, 2008
You're definately looking at it the right way. You should be gearing the car to top out in 4th gear at the end of the track. Honestly, I would go with the 4.10s. They aren't that bad on the street, and the car should go faster.
Kurt
T
Touring23
294
Washington
Dec 11, 2008
  • Dec 11, 2008
Thanks guys. It's not a DD, I think I drove it maybe 2,000miles in the last two years, so fuel mileage isn't a big concern.
I found this thread along the same lines.
Hhhmmmm...................
Black95GTS
1,644
Marlborough, MA
Dec 12, 2008
  • Dec 12, 2008
4.10s and don't think twice. For very short dollars you can retard your camshaft timing to move the power up a few hundred RPM as well.
Adam
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
Weight Guess, And 1/4 Goal With Turbo
  • 89BlackGTvert
  • Aug 5, 2012
  • Fox Engine Swaparoo
2K
Fox Engine Swaparoo Nov 26, 2012
Incon
Drag Racing Tips.. (Borrowed)
  • radtexas
  • Oct 5, 2006
2005 - 2014 S-197 Mustang -General/Talk- Oct 5, 2006
PDXStangDude
302 Stroker Information
  • 5spd GT
  • Sep 12, 2007
66K
Fox 5.0 Mustang Tech Oct 26, 2007
bullitstang1313
9
Finally! AFR/FTI Dyno AND Track Results are In
  • 94DreamGT
  • May 30, 2004
  • 2 3
3K
1994 - 1995 Specific Tech Jun 1, 2004
tmoss
