Drilling 1250s For Egr
I wasn't attacking you if that's what you thought . It was legitimate question . I asked because no matter what rad and fan setup on a hot summer day you may see 200 deg in traffic. So only being 12 deg from a boil over point at 14.7 psi or so if your at sea level is just something id want to avoid .
The coolant is gonna want to turn to steam much faster . I thought there was some other reason behind it as I'm always interested in learning and extra ways to keep my car cool . I work on diesel stuff for a living so I thought maybe there was something I hadn't thought of or was missing .
Rest assured I did not take it as an attack.
Any idea what the coolant pressure level gets to under normal conditions? For instance, if you run a 16lb cap, will it run at 16lb and bleed off anything higher? Or will it normally stay under 16lb anyway?
In thinking about putting the stock rated 16lb cap back on.
That is the premise that cap should not blow unless it exceeds 16lbs of pressure . But at or under 16 pounds it changes the boiling point of the water or antifreeze and keeps it from starting to turn to steam at 212 ( if it were straight water ) . 50/50 is obviously a higher temp to boil due to the additives
Reactions: JD1964
