Putting the finishing touches on the TCP manual rack install. To clear the rack and pinion bellows I had to grind down the inner tie rod ends and ended up grinding off the section that has the hole for the cotter pin. The kit included two nuts with nylon bushings that replace the castle nut, but I don't trust that setup.
So far I've broken two titanium 1/8" bits and one HSS bit trying to drill through the tie rod end. I am using lots of cutting oil but having no luck.
Any suggestions? Should I go to a machine shop and see if they can do anything?
This is the last thing to do before I take it to the alignment shop. Any help appreciated.
Thanks in advance, Mike
