Driveablilty problem
1badsuv
32
Humboldt, Kansas
Greetings all
I normally hang out on another ford enthusiast site, they recommended I come here with my problem. Several are mustang owners, and as I have more of a mustang engine than the stock explorer engine in my Mountaineer, it makes sense
here goes
Since I installed this ( nothing stock) engine, I have been plagued with a small drivability issue.
Everything is going great, no CEL, good gas mileage, great performence etc.
However, when driving at highway speed, then needing to slow down, upon deceleration my engine wants to surge. Lifting from throttle, when engine speed slows to 1000 rpm's, it will rev to about 1700, back down, back up, until either transmission is shifted to neutral, or vehicle is slowed to below 10 mph in drive, at which time the idle will stabilize.
vroom, vroom, vroom vroom, when I slow from speed---get it?
So, I first thought IAC
disconnected it, CEL on and still vroom vroom when slowing
new TPS installed
vroom vrooom vrooom
I then drilled 1/8" hole in throttle butterfly to facilitate lower TPS voltage at idle
vrooom vrooom vroom
so to be sure I installed a new intake manifold gasket and fuel injector o rings
vroom
T/M headers to fix the ticking ( maybe a leak getting in?)
vroom
I conferenced on vacuum diagram, to double check.
vrooom
When the Rpm's rise, vacuum goes down, and vice versa.
both needles bounce opposite of each other, until it stops revving
This tells me something is opening to allow vacuum pressure loss
EGR!!!!!!
I installed a 1 way vacuum valve to the EGR valve. I was hoping to lessen the vacuum pulse to it. It seemed to help momentarily, however, being a 1 way valve, it builds a vacuum. It ended up holding the egr valve open.
When I removed it I could hear the valve close as the presure was released--
Could it be my EGR vacuum solenoid freaking out?
My next step---remove vacuum line from EGR valve- plug it and road test???
HELP
Once, due to the revving, my wife slowing for a curve, the engine died because of it.
Not good when my woman looses power accessories,
other than this issue, it is woman tame
BTW
I am in no way interested in bypassing the EGR circuit.
I will post here my engine stuff
In case anybody has an idea
new sportsman block
bored .030
billet crank
h beams
10.1 cr probe PRS Pistons
Edelbrock performer efi head stage 2
58 cc Combustion chamber
180 cc intake runner
X cam 4 degrees advanced
typhoon intake
75mm Tb
Prom Big mouth 80mm maf and maf tuner
aeromotive fuel rails-regulator
42lb FMS flow matched injectors
High volume in tank pump
At idle, 1000-1100 rpms, she pulls 16 inches of vacuum
__________________
The sound of Torquemonster headers
Yes it is an X Cam
http://media.putfile.com/Torquemonster-exhaust
__________________
I know some stangs, especially the cruise control ponys and autos, came with a sensor that was mounted on the speedo cable right where the speedo gear enters the tranny. Does your have this sensor or atleast the harness for it? That could explain the surges possibly. I have the harness but no sensor right now as I have the wrong speedo cable in it. When I stop quickly my cars rpm will drop down to 350-400rpm range (almost stall) and then surge up to like 1400 then drop back to idle. Kinda annoying and the quicker the stop the lower the drop and higher the surge. Just a suggestion to look into...
EDIT**
I didn't notice you have this in a mountaineer... so chances are you can discard my suggestion.
Thanks for the quick response
I am running the stock 98 explorer OBDII pcm
It controls and monitors the transmission completely, Speed is sensed by the VSS , no speedometer cable
The transmission is a 4R70W, with a divorced AWD transfer case
My ENGINE is exactly like a 94-95 mustang, with 98 mustang electronics, It is DIS ignition
86bluecobra said:
why do you have such big injectors seems over kill unless this thing has a S\C.
It is going to, or most likely a remote mount turbo
heh heh
Fuel pressure doesn't effect this issue, runs at 33 psi now ( at 1:1) 23 psi at idle
This setup seems to like lower pressures with these huge injectors.
Does it only happen if you are rolling?
If so, your thoughts were the same as mine - disco' the IAC to remove the rolling idle strategy. If it only happens during a rolling idle however, I'd read up on the EEC strategies to see what other sensors and solenoids (that don't use the IAC as their slave) have input in said circumstances. The list should be small.
If you're going to get a handheld for the F/I, you could do it now and tune the issue away probably.
Good luck.
EDIT: I'd also check the mod motor sub-forum as this sounds more like an EEC issue than a mechanical issue. They probably deal with issues we've never heard of.
Good luck.
Good luck.
Good luck.
Ok
Check this
I have eliminated the IAC 2 ways, both with no effect on the rolling surge
My BBK throttle body has an IAC circuit adjuster, which I have closed off completely trying to eliminate this
also, as I said I did disconnect the iac, This time I got a CEL ( 1406) i think
idles speed control circuit error,
any way
So
Upon further experimenting, I read the mafs voltage has something to do with the EGR solenoid signal, which leads me to the EGR.
To verify, while the rolling surge is occuring, I can adjust the lowest band of my MAF tuner, just a bit towrd the richer side, and the surge stops.
However, leaving it in this tune will triggger a cel Bank 1 and 2 rich.
This coinicides with the reading on my air fuel ratio gauge.
I would bet a good handheld scanner-tuner would be my fix for sure, and get rid of my 5400 rpm limiter also hahaha
Oh wow
HISSIN50 said:
i would add that some IAC's need to be installed upside down to function properly (it should say so in the instructions).
does the idle drop when you have it running (warm motor) and disconnect the ISC connector? if so, i would really hit that EGR. even if this does not happen, i would jump the code. if you are introducing EGR gasses at idle, the car will likely not idle or idle terribly.
good luck.
:OT: hey, Id, how ya been? :)
old quote
Are you familiar with a spacer between the IAC and Throttle body, with flow adjustment? This might allow me to mount mine reversed from it's current position
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-9939A 1&comp=LRS
Yes, I am familiar with the spacer/bleeder. My take is that this is why the 94-95 5.0L stangs have the bleed adjuster in stock form. You have a bleed adjuster already, no? On a 94-95 Stang, it's an allen-head adjuster that sits under a rubber plug. It's how the manual suggests setting the idle (which I don't agree with, in reality).
The thing about the IAC in my quote above: That was something I'd only run across with foxes. There are issues with some aftermarket 94-95 IACs - OEM and the Borg Warner unit (the latter being available at the parts store) work well. Others are hit or miss.
Going back to the EGR pondering you did: if your EGR was opening, your idle would surge from normal to near stalling. It sounds like the base idle is in the ballpark (near the commanded idle setting) or we'd wonder if the IAC is simply sticking open (no?).
Sorry for being hard to follow. I'm beat.
Me also
Pick up later on this?
I'll post more after I try a thing or two.
BTW
Yes, my BBK throttle body has a iac adjustment screw, and an idle set screw.
I have even closed the iac screw all the way, surge still occurs:bang:
Thank you very much for the help
