driveline noise
  • Thread starter Thread starter 6Stang7
  • Start date Start date Jun 15, 2004
6Stang7
1,470
Livermore, CA
Jun 15, 2004
  • Jun 15, 2004
If I am driving in first gear (only gear I have tried it in so far) and I left off the gas so that the car drives the motor, I will get a clunking noise from the driveline when I push the clutch in. This doesn't happen though if I push the clutch in before I let off the gas (not letting the car drive the motor). Is this normal, or a sign of a problem starting? If I am being to vauge here let me know.
6Stang7
1,470
Livermore, CA
Jun 15, 2004
  • Jun 15, 2004
bump
70MustangGrande
992
Somewhere in Alameda, California
Jun 15, 2004
  • Jun 15, 2004
First gear only eh...
Could be the clutch isn't engaged fully in first, worn out cog in transmission, worn out driveline (easy fix with new pins) couldn't give you a gaurantee on an answer.
6Stang7
1,470
Livermore, CA
Jun 16, 2004
  • Jun 16, 2004
The U-joint in the rear is new and I haven't had any problem with the clutch slipping. I am just worried that I might have yet another part in my driveline fail.
R
Ronstang
1,294
Houston Texas
Jun 16, 2004
  • Jun 16, 2004
Check to make sure your ring and pinion do not have too much backlash in them, as they wear they can cause quite a jolt upon decceleration due to all the slop. You can tighten it up a bit if necessary also if you have the right tools.
6Stang7
1,470
Livermore, CA
Jun 17, 2004
  • Jun 17, 2004
Ok I went out today and disconnected the driveshaft from the diff. I then grabbed the pinion and was able to turn it back and forth some without the tire moving, so I am going to ask the diff shop to decrese the amount of backslash on it. I also grabbed the driveshaft and did the same thing with the transmission in gear and had some play there too, but not as much as the diff had (about 2/3-1/2 less). Is it normal for a transmission to have some play? If it is, does anyone know about how much and a way I can check to see if it is all in spec. Same with the diff too if you know.
STSFCTN67
450
Denver, CO
Jun 18, 2004
  • Jun 18, 2004
I had a very similar problem when I first installed my T5. After eliminating exhaust and driveshaft problems I got underneath the car with a rubber mallet and started bumping everything until I found the noise was coming from my new tranny mount. The mount was fine but for some reason when I let off the gas and was descellerating the mount wounld vibrate. I ended up placing two thick washers in between the tranny mount and the T5 swap bracket and it solved the problem.
6Stang7
1,470
Livermore, CA
Jun 21, 2004
  • Jun 21, 2004
Does anyone have any comments on the amount of slop I have though? Whenever I shift gears I get a sudden jurk cause there is that much slop in the driveline (unless I let the clutch out REALLY REALLY SLOW).
1969mach1351
285
Sacramento, CA
Jun 21, 2004
  • Jun 21, 2004
My locker has about 1/8 turn of play in it. Lockers normally have more play than others. Didn't you try a locker not too long ago? Did you just put back in your old stuff? I know with a manual tranny you will feel the play in the rear between shifts if you had a locker. Since I have an auto I only notice mine going from park to drive. Do you have more than an 1/8 turn of play?
I'm from Livermore, just curious what shop are you having do you rear?
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
