Driver's side window came off track?
Driving home last night, I lowered the window on my 94 GT and heard a loud "clunk" when it reached the bottom. Now the window does not want to go all the way up, and has problems going up and down in general. You can hear the window motor spinning and this sort of repeating clunk sound when the window is moving.. so I assume it's off track.
How do I go about fixing this?
EDIT: ok, I'm gonna assume I need to take the door panel off. =) I tried to do that this evening but I had some troubles. Can anyone provide some insight on what the detailed procedure is on getting the door panel off?
It might be your window motor. There is a write-up in the FAQ section about replacing it. It should show you how to take the door panel and all that out. It's been over a year since I had to replace mine, so I don't remember exactly how. But I know there are a bunch of tabs you need to pop out along the bottom of the door, and you need to take your window switch bezel out too. Then there's a screw or two behind there you need to remove. Good luck.
Looks like there's a problem with the FAQ's search function. Anyone else out there familiar with taking the door panel off?
