  • SN95 4.6L Mustang Tech
Drivers window is binding
  • Thread starter Thread starter Team Ford
  • Start date Start date Sep 15, 2006
Team Ford
109
  • Sep 15, 2006
So, I was thinking about my abs light as I left the parking garage and while putting up my window it acted as if it just fell off the track. I was like Greaaat!
I took the door apart which was very easy (ty ford) and found a piece of heavy sound deadener that fell down on one side causing the window to bind at the bottom of its travel. I pulled the other corner down and removed the deadener - problem solved.
nwapache
313
Seattle,WA
Sep 15, 2006
  • Sep 15, 2006
welcome to Ford
M
my95gtstang
76
Chesapeake, VA
Sep 15, 2006
  • Sep 15, 2006
nwapache said:
welcome to Ford
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Sep 15, 2006
  • Sep 15, 2006
Nice, hope thats my problem too. How do you pop the door panel off? Are there clips?
Les Paul
488
Revere, MA
Sep 16, 2006
  • Sep 16, 2006
I wish I had the same luck. My window just cost me over $600.00 to have replaced and fixed. Long story. If i have to repeat my head will explode. Glad it was nothing.
CRZYHRSGT
240
5.7 miles north of THE Ohio State University
Sep 16, 2006
  • Sep 16, 2006
nwapache said:
welcome to Ford
Could be worse...VW Golf, Jetta and New Beetle windows would just fall into the door. I guess making a window go up and down is something new for these auto manufacturers.
As far as the door panel, you have to take the interior pull handle/switch bezel thingy off and there are 2 phillips head screws in there. Next you have a push pin on the edge of the panel facing the door hinges. After that you should be able to lift it up and towards you.
E
exindust
329
Moorpark, CA
Sep 16, 2006
  • Sep 16, 2006
Yeah 2 screws, one flip and 12 clips hinged onto the door.
Yay 4 "4d"
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Electrical Fried my window motor…
  • AnthonyA1234
  • Oct 25, 2024
Fox 5.0 Mustang Tech Oct 26, 2024
General karthief
M
Window issues
  • Meierznutz
  • Jun 25, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 28, 2024
AeroCoupe
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
W
2012 Base Convertible Driver Side Power Window Will Not Work
  • wmmihail
  • May 25, 2024
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech May 25, 2024
