driveshaft angle question
  • Thread starter Thread starter 351w_swap
  • Start date Start date Mar 13, 2007
351w_swap
263
  • Mar 13, 2007
I am completely rebuilding my car and I am planning to completely disregard the stock mounting points on everything. I will move the engine and tranny back several inches to get better weight distribution as well as a more comfortable grip on the shifter. I realize that this will probably mean cutting the firewall but that will be done anyway. The ride height will be quite low meaning that I will be fitting some 315s inside the fenders. Am I going to run into problems with drive shaft angle because by current measurements, the driveshaft (custom built to spec) will be at almost no angle to the transmission? If there is any problems with this, please post your thoughts, thanks
iskwezm
4,159
20
79
Rowland Heights,California
Mar 13, 2007
  • Mar 13, 2007
i think you want about 2-3* downward on the rear of the driveshaft so when the torque is applied and it wants to move upward it will be at 0*(level).Just my guess
351w_swap
263
  • Mar 13, 2007
The 4 link will be tuned to provide down force through torque so Im not worried about that, I am just worried about u joint binding or something
66Runt
680
Mar 13, 2007
  • Mar 13, 2007
T
Tom Foolery
  • Mar 13, 2007
My chassis book says 5-7 degrees nosedown for standard leaf spring,
3-5 degrees nosedown for Leaf-link
2 degrees nosedown for 4-bar link
1 degree nosedown for single pivot ladder bar
The idea being a straight driveline with pinion on launch.
351w_swap
263
  • Mar 14, 2007
can anybody recommend some good chassis reading. I would like to get a book but webpages are ok too, thanks
LW_horse
37
Sweden
Mar 14, 2007
  • Mar 14, 2007
Have a look at this link. You will find answers to the most of your questions there:
http://www.drivetrain.com/driveline_angle_problem.html
Two things that solved my long, and expensive, issue with driveshaft vibrations:
¤ Always invest in Billet yokes (especially the one on the rear axle). Do NOT go with the cast Spicer stuff..
¤ Make sure u-joint angles are 1-3 degrees, & within 1 degree from one another (see better description in link).
Good luck
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
