I am completely rebuilding my car and I am planning to completely disregard the stock mounting points on everything. I will move the engine and tranny back several inches to get better weight distribution as well as a more comfortable grip on the shifter. I realize that this will probably mean cutting the firewall but that will be done anyway. The ride height will be quite low meaning that I will be fitting some 315s inside the fenders. Am I going to run into problems with drive shaft angle because by current measurements, the driveshaft (custom built to spec) will be at almost no angle to the transmission? If there is any problems with this, please post your thoughts, thanks
