- Apr 4, 2005
- 156
- 0
- 0
In my quest to get the f*(&(*&) 60mph vibration to go away, I jacked the car up, put jackstands under the axle and checked the driveshaft. I wedged a straightedge between the mufflers up against the driveshaft and spun the wheel. The driveshaft "wobbles" between 1/16 to 1/8 of an inch up and down from the straightedge. Is this normal? Or might this be the cause of my vibration? It has all the weights attached and stuff, doesn't look like there are any areas where one fell off.
Also, There are worn rings around 2 or 3 (can't remember) parts of the axle about 3/4" wide. Looks like it rubbed on something because the rust of scraped off. Then one long deep scratch about 1 foot long down the driveshaft (front to back). BUT, there is no damage to the mufflers or anything around it.
Any ideas??
Thanks!
Any ideas??
Thanks!
They went up big time in price last year. I got mine from Ramchargers for 219, but that's only because I knew a guy who worked there and he gave me his discount. Most of the places iwho advertise in the Ford mags list them for 249.
Why would you want to do that? The f-150 d/s does have a larger O/D , but the inside wall thickness is no where near that of the aftermarket FRPP Mustang shaft. The FRPP shaft is 1,000 times stronger than the f-150 shaft.
