Driveshaft bolt removal
  • Thread starter Thread starter 5.0 Nostalgia
  • Start date Start date Sep 7, 2004
  • 3
First Prev 2 of 3 Next Last
cevtv
1,113
Massachusetts
Sep 8, 2004
#21
  • Sep 8, 2004
  • #21
MUSTANGJOE said:
Oh yeah! When you reinstall those bolts make sure you really tighten them ..try to go to a shop and let them use there air tools..because I retightened mine by hand and a week later my car started to vibrate, so I went to the shop and my diff was about to come right off! the bolts fell off and it was running on 1 bolt which was about to come off too! I just could imagine the damage that would of caused!..Anyways good luck!
That's because you NEED to use thread locker on the bolts!
J
jerry beach
2,671
Ocala,FL
Sep 8, 2004
#22
  • Sep 8, 2004
  • #22
Leg press is good, thats how I got mine off, not torch needed and it didnt take long at all. I put blue loc-tite on them and tightened the crap out of them with my foot again. They came loose again. The next time, I put red loc-tite on them ( stud and bearing formula). They have been staying tight since then. When they start to come loose, you will hear and feel a slight clunk under the car when you start to let the clutch out sometimes. They are the first thing to check when you hear a clunk in the drive train.
Ray III
586
fixin Boomhower's John Deere in Troy, NY
Sep 8, 2004
#23
  • Sep 8, 2004
  • #23
Red or blue loctite?
If the stuff is RED then the torching makes sense because that is how red loctite is supposed to be released.
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 8, 2004
#24
  • Sep 8, 2004
  • #24
Well that makes more sence!
cevtv
1,113
Massachusetts
Sep 8, 2004
#25
  • Sep 8, 2004
  • #25
From the factory it is the same as the red.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 8, 2004
#26
  • Sep 8, 2004
  • #26
Huh....you guys do a lot of work for nothing. All it too was a good 12-point wrench and a quick whack with the hammer to get mine loose. No stress required.
Tightend them up the same way. Good to go.
5.0 Nostalgia
904
CT
Sep 8, 2004
#27
  • Sep 8, 2004
  • #27
Guys, I got the bolts loose. And the winner is...Daniel's method of using the jack. Couldn't get much easier than that. Just a little PB, wait 5 minutes, put the wrench on, and jack it up.
5.0 Nostalgia
904
CT
Sep 8, 2004
#28
  • Sep 8, 2004
  • #28
Now before I make a mess, do I need to drain the transmission fluid before I take it out? When I pulled the trans on my old GT, I don't remember if I drained the fluid first or after. Right now the car I am working on has a T5. The other car was a AOD and I just dropped the pan. How do I drain the fluid on a T5?
D
Daggar
3,902
#29
  • Sep 8, 2004
  • #29
Nah... plastic bag and a couple of rubber bands is good enough for removal and replacement.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 8, 2004
#30
  • Sep 8, 2004
  • #30
Keep-er-level.
cevtv
1,113
Massachusetts
Sep 8, 2004
#31
  • Sep 8, 2004
  • #31
Yeah...it'll pour out of the speedo gear hole, too.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 8, 2004
#32
  • Sep 8, 2004
  • #32
Not all bolts are tightened equally...do to age, previous work, etc...
My bolts snapped a socket in two pieces...it twisted it and shot off from an impact gun...
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 8, 2004
#33
  • Sep 8, 2004
  • #33
They make a tailshaft plug that goes into the end of the trans that will plug it up when you take out the driveshaft...it is like $3 bucks...but the rubber band and ziploc bag trick would be just fine...
cevtv
1,113
Massachusetts
Sep 8, 2004
#34
  • Sep 8, 2004
  • #34
This is why you should heat it first........it would suck to twist the head off of a bolt, and have to try to get the rest of the bolt out of the pinion flange.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 8, 2004
#35
  • Sep 8, 2004
  • #35
Ahh...it wouldn't be to big of a deal...we brought out the torch after that...no problem at all...either way...
cevtv
1,113
Massachusetts
Sep 8, 2004
#36
  • Sep 8, 2004
  • #36
Personally I don't know how comfortable I would be superheating the area. It might be ok for your average bolt of car, but I wouldn't want to risk taking the temperament out of the bolts or flange when real horsepower and torque is applied. Might find yourself at the starting line with a spinning drive shaft and no forward momentum. Or worse yet have it come off half track and pole vault your way to the finish line.....on your roof.
Who said anything about "superheating"?????? Just heat it enough to loosen the loctite - only a few seconds. If that changes the temper of the bolt, the bolt was screwed to begin with. Have you ever read the Red Loctite directions??? They say "localized heating and hand tools are required to seperate parts".
You guys are thinking WAY too much about this........
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 8, 2004
#37
  • Sep 8, 2004
  • #37
cevtv
1,113
Massachusetts
Sep 8, 2004
#38
  • Sep 8, 2004
  • #38
Whoa....how did my reply get in before the post I replied too???
bgjohnson
963
johnston,iowa
Sep 8, 2004
#39
  • Sep 8, 2004
  • #39
yeah those things are a bitch , i just used the double wrench and my "breaking loose" arm, haha
5.0 Nostalgia
904
CT
Sep 8, 2004
#40
  • Sep 8, 2004
  • #40
I thought about the heat causing a problem too. But then again, I thought the jack would be putting a lot of stress on the rear end. Then I thought I am over analyzing the problem and my transmission is not going to get fixed if I keep messing around with something this minor.
  • 3
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
