Driveshaft bolt removal
  • Thread starter Thread starter 5.0 Nostalgia
  • Start date Start date Sep 7, 2004
  • 3
First Prev 3 of 3
T
TheDevil
393
Monkey paw
Sep 8, 2004
#41
  • Sep 8, 2004
  • #41
5.0 Nostalgia said:
Guys, I got the bolts loose. And the winner is...Daniel's method of using the jack. Couldn't get much easier than that. Just a little PB, wait 5 minutes, put the wrench on, and jack it up.
Kewl, glad you got it done!
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 8, 2004
#42
  • Sep 8, 2004
  • #42
cevtv said:
Who said anything about "superheating"?????? Just heat it enough to loosen the loctite - only a few seconds. If that changes the temper of the bolt, the bolt was screwed to begin with. Have you ever read the Red Loctite directions??? They say "localized heating and hand tools are required to seperate parts".
You guys are thinking WAY too much about this........
I don't know why my post warranted a , but I wasn't just referring to removal of a bolt covered in loc-tite. It was a general statement that referred to a common practice when getting rusted and ceased bolts out, is to superheat them with a torch. While it’s successful 99% of the time, it does tend to take the temper out of them and if you're not careful, the surface they’re mounted in/on. This makes them/the area potentially brittle and prone to breakage.
....and I don't have a clue why the board is doing this tonight?
Ray III
586
fixin Boomhower's John Deere in Troy, NY
Sep 9, 2004
#43
  • Sep 9, 2004
  • #43
When you heat a part red hot and then let it cool that tempers it. It is probably not as good a tempered bolt from a manufacturer, but it will be PLENTY hard.
Heating a part up, then letting it cool SLOWLY, by very gradually removing heat, is what anneals it by giving the molecules time to rearrange into a weaker state.
Nothing wrong with replacing heated bolts if you want to be safe. But from my experience, it is generally not necessary.
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 9, 2004
#44
  • Sep 9, 2004
  • #44
But is your car jacked up on jacks or a lift? that makes a difference!
rd
3,316
63
109
Ocean Springs MS
Sep 9, 2004
#45
  • Sep 9, 2004
  • #45
From my 79 and 82 car experience, I would suggest getting a 12 mm, 12 point socket. I use this with an extension, and usually put an adapter on so I can use a 1/2 in drive breaker bar. If you had a 1/2 drive,, 12 mm, 12 point socket, you could eliminate the adapter. This will allow a socket on the bolts in the lower position.
I had the socket for some other reason, and it just became the tool for this job when I got these cars.
The breaker bar does accommodate extension with a piece of pipe if you need it. Put the handle and pipe in the horizontal position and put a jack under one end if need to apply overwhelming force.
Most of the time, after I have done it once, for a couple years they will come off with a plain 12 point box wrench.
(appologies if I remembered the wrong size)
Ray III
586
Sep 9, 2004
#46
  • Sep 9, 2004
  • #46
Yes it is 12mm but if a Snap-On ratchet would not fit in there, what will?
  • 3
First Prev 3 of 3
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
