Driveshaft for T5 conversion
It will bolt in but it will most likely need shortened about 1", that seems to be the average for a T5 swap. There are a few variables here. The best way is to crawl under the car and get a best guesstimate, then take the driveshaft to a shop and have them shorten it to your specification. I did this for mine and it was indeed 1".
I'm not 100% sure what my overall length is to be honest. Let me know if you don't have a driveshaft at all and need to have one made, I'll crawl under my car and measure it for you.
Btw, welcome to Stangnet! :)
Reactions: 2Blue2
Thanks for the info. It actually doesn’t have a drive shaft, so I’ll need to get one.
Reactions: LILCBRA
Ok, this will be a ROUGH measurement, but should get you in the ballpark. I was in a pretty bad position to ensure I was measuring from both U-joint centerlines, but CL to CL was around 44-45".
