Driveshaft removal
SN95StangMan
1,292
Lynwood, CA
OK, I got the 4 bolts off of the rear end. Is the part or the driveshaft that connects to the rear end supposed to slide down so that I can pull it back and out of the trans? Right now the driveshaft is just sitting the way it was before I removed the bolts. I tried pulling it down but that sucker is on there tight! Any tips on how to get this thing off?
If you stick a large screwdriver inbetween he driveshaft and the rear axle and pry in back, the driveshaft will disconnect from the axles and move towards the front of the car. Then you just pull the driveshaft right out of the tranny. Takes some elbow grease but isn't too hard to do.
