  • SN95 4.6L Mustang Tech
Driveshaft vibration
  • Thread starter Thread starter LaserSVT
  • Start date Start date Aug 20, 2007
LaserSVT
3,548
233
Aug 20, 2007
  • Aug 20, 2007
I am noticing a vibration in the car when I go over 100. Starts as a humm and builds with speed. When I let off the throttle at high speeds 120+ it will shake the stick untill the car drops below 100. Is this drivesgaft vibration? It is still the stock one, should I get an aluminium one?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 21, 2007
  • Aug 21, 2007
It could be your trans mount or your rear end/rear control arm bushings. Check those. Also, have the ballance checked on the driveshaft but I doubt that is the issue.
Stus99GT
75
VA
Aug 21, 2007
  • Aug 21, 2007
I had the same problem after my gear install. A FMS aluminum driveshaft fixed the problem.
Samz281
  • Aug 22, 2007
Just so happens I am selling a brand new FRPP ALUMINUM Driveshaft for $225.00 Let me know if you would like it....If you buy it somewhere else..its gonna run u $50 more....
00GTpony
162
  • Aug 22, 2007
YOu could check the U joints in your driveshaft, or mayb its as simple as your tires need sum balancing
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
