- Jul 9, 2010
- 2
- 0
- 0
Hey guys. So a bit of background on the issue, my manual trani recently got stuck in 4th gear and no matter what I tried I couldn't get it out of gear, this trani has also had some other problems so I just decided to replace it. Now I have the car on 4 jack stands and I'm trying to remove the driveshaft. I managed to remove 2 bolts (the ones that are visible at the moment) but the other 2 require that the driveshaft be rotated before I can have access to them, that's where I hit a snag. I took off the e-brake and rotated the rear tires by hand and the drive shaft didn't spin! I asked a friend to jump in the car and I tried rotating the tires with the clutch pressed and without and still no luck. The wheels rotate freely and the driveshaft stays in place. So my question is, how can I get the driveshaft to rotate so I can get access to those screws?
Thanks,
Jose
Thanks,
Jose
