  • 2005 - 2009 Specific Tech
Driveshaft
  • Thread starter Thread starter JTGrant
  • Start date Start date Nov 7, 2005
JTGrant
775
GA
Nov 7, 2005
  • Nov 7, 2005
after installing my gears I have a vibration at 90mph+ I think that it is the driveshaft. I marked the shaft before removing it from the yoke, but the markings wore off. Does anyone know the way thw driveshaft is to line up? There are no factory markings and the only thing that could be vibrating is the driveshaft. There three different ways to install this shaft. It's not like that old ones. What else could cause a vibration/rumble over 90 mph? Good gear pattern, backlash .010.
JTGrant
775
GA
Nov 7, 2005
  • Nov 7, 2005
can someone look at their driveshaft and see if the holes that are drilled in the pinoin yoke are opposite of the weight that is on the driveshaft?
JTGrant
775
GA
Nov 8, 2005
  • Nov 8, 2005
anyone have a clue?
Tri-Bar
68
Ca
Nov 8, 2005
  • Nov 8, 2005
Sometime rotating it 90* will help. try that first.
JTGrant
775
GA
Nov 8, 2005
  • Nov 8, 2005
yeah that is what I'm doing hopefully that will help......
4.10's Rule!
G
gpp
137
  • Nov 8, 2005
here is the story.4.10 richmond gears,bad whine and vibration.3.73 ford gears,no whine same vibration.didnt have the vibration until the gear swaps.so,rotated the drive shaft in all five positions plus original,no better than it was in the original factory spot.took the bolts out one at a time and put a 3/8 flat washer on the them and reinstalled the bolt. not alot of change.kept doing this for each bolt but didnt move the shaft.got to the 5 th bolt hole and good gu be do,90% of the vibration was GONE!took the bolt out,added one more washer and if it got any smoother i would think it was going to fly all to pieces.i never would have believed this would work but it did.it vibrated real bad at 65 mph and now you would never know it did it.thank you joe lynch who ever you are,you are my hero.this worked for me and it is worth the time to try it.when you try the washers dont leave them on as you try the differant position until you find the smoothest spot.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Nov 8, 2005
  • Nov 8, 2005
so the washer goes between the bolt and drive shaft and is used like a balancing weight?
JTGrant
775
GA
Nov 8, 2005
  • Nov 8, 2005
where do they go?
G
gpp
137
  • Nov 8, 2005
thats what it seems do.when you pull the bolt out of the first of 6 differant holes you just put the washer on the bolt and re install.see if any thing changes,take the bolt and washer out.put the bolt minus washer back in the hole and go to the next bolt and do the same.when i found the one with the smoothest setting i added another washer to see if it helped which it did.a third washer didnt change anything so i left the 2 washers on it.its alot of trial and error and time but if it works its very satisfying.may or may not work in all cases but it worked in my case.
JTGrant
775
GA
Nov 9, 2005
#10
  • Nov 9, 2005
  • #10
but where is the driveshaft weight according to the holes drilled in the yoke? Teh vibration is only at a certain speed 60 mph. I took the rearend apart again last night. The backlash was off the carrier had some freeplay, so everthing is good now but the vibration. It has to be the driveshaft. See on my driveshaft there are holes drilled into the pinion yoke and on the driveshaft there is a weight welded to the shaft.
G
gpp
137
#11
  • Nov 10, 2005
  • #11
thats about where my vibration was until i did the rotating and washer.forget the original weights and holes,just rotate it like i did and see what it does.like bigcat said its just like adding more weight to the drive shaft.and my drive shaft has the welded on weight also.didnt see any holes.
lenko
66
Southern Alberta
Aug 27, 2007
#12
  • Aug 27, 2007
  • #12
3.73 gear vibration
I was also experiencing a 62-65 m.p.h. vibration after installing 3.73 gears in my 06 Auto. Tried the washer trick after reading this thread and am glad I did as luckily I got rid of the vibration after only the second bolt. Where would a guy be without all this help on the forums?
06 Tungsten GT, C&L, X-Cal 2, Brenspeed , 91 octane, UDPs, delete plates, Cobra Ft., Homelink mirror and 3.73 FRPP gears with washer trick.
BJ1000RR
58
New Orleans, La
Aug 28, 2007
#13
  • Aug 28, 2007
  • #13
What kind of driveshaft are you guys running ?
I have the COAST and I didnt even know the shaft had to be ligned up a certin way, I just bolted it up with no problems.
Just Wondering
lenko
66
Southern Alberta
Aug 28, 2007
#14
  • Aug 28, 2007
  • #14
Just Wondering
Just the stock driveshaft for now. Premarked it before the gears and put it on the same way but had a slight vibration until I put a washer on the bolt.
lenko
BJ1000RR
58
New Orleans, La
Aug 28, 2007
#15
  • Aug 28, 2007
  • #15
OH. Didnt know the driveshaft had to come out for gears. Learn somethin every day. huh
What brand driveshaft are the rest of you guys running?
mhanksii
336
Maryland
Aug 28, 2007
#16
  • Aug 28, 2007
  • #16
Stock but I want a coast very badly
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
