Driveshaft ?
BlackLX5.0
76
I put an 89 Lincoln TC transmission in my 91 Lx. When I went to put the driveshaft back in, it wouldn't fit. It was too long, so I went to the junkyard and found another driveshaft. The yolk is 6 inches long and it goes up in the transmission, But theres only 2 1/2 inches in there now, the rest is sticking out. The driveshaft was just a little to short. Would it hurt anything if it just has 2 1/2 inches in the transmission?
Sorry If this sounds confusing lmao I just woke up.
Thanks :SNSign:
Not sure if this helps out now or not, but Ford had 2 different extension housing lengths over the years. Around 11" and 13" and they used them in different models over the years. If you still have the old tranny, you could swap extension housings. :shrug:
Yes, there are two lengths for AOD and related trans. The output shaft and tail housing can be swapped, but you have to totally dissassemble the trans to swap the output shaft.
You may be able to get a shorter Mustang driveshaft, as, for example, a straight 6 c4 shaft is shorter. It had only about 1 1/2 in of engagement on my 5.0 C4 setup.
Easiest is to just get a shaft shortened. Once you find a shop, you find out they do this all the time.
