drivetrain problems?
  • Thread starter Thread starter l2ol33rt
  • Start date Start date Apr 9, 2007
l2ol33rt
23
  • Apr 9, 2007
So here the story, i just finished breaking in my new clutch which is a centerforce stage II. My first time on the freeway i am cruising in 4th at 2000rpm i go to pass someone and as soon as i get to 2500 rpm the car started to freak out. It seemed like either 4th gear is gone or somethings wrong with the clutch i just installed. The power would cut out then come back on. Prior to the install i had no problems with 4th. The car runs well throughout the rpm range in 1st-3rd. I thought maybe its the fuel pump starving the car since its probably never been replaced and i have 155000 miles on the car.
Thanks in advance,
Robert
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 9, 2007
  • Apr 9, 2007
I highly doubt the clutch has much to do with this problem.
When you describe power as cutting out then coming back on where the RPMS climbing and falling off? Did it feel like you clutch was slipping? Sounds like an engine issue with either spark or fuel to me.
l2ol33rt
23
  • Apr 9, 2007
O man thats a relief i feel much better knowing that this is either a problem with spark or fuel! when it cuts out the rpms drop a little then it just comes back on. i was thinking maybe replace the fuel pump and check the order of the plug wires and timing any other ideas?
Aryan15
236
CA
Apr 9, 2007
  • Apr 9, 2007
Pull the codes. Im not sure, but maybe the VSS.
ninety15.0
1,336
  • Apr 10, 2007
If you had the wrong firing order, it wouldnt run well in 1st through 3rd and then all of a sudden cut out in 4th. Check the fuel filter if it hasnt been changed in the last year...pull the plugs and check the color and gaps. Also take a look and the cap and rotor and check the brass terminals for wear. The only way to check the fuel pumps performance would be to get a fuel pressure gauge on there and check the press drop while your making a hard pull. Unless the clutch is slipping (and i think you would notice this) then its not a clutch problem.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
Reduced power in 1st and 2nd gear
  • jimted79
  • Feb 25, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 25, 2025
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
