Soooo, decided to tackle the Granatelli rear diff cover/girdle installation yesterday on the '94, but Mr Murphy seemed to make an unexpected appearance. I know others in here have tackled this project before so maybe one of you can shed some light on my problem.
Here is where I am hung up at. I removed the the factory diff cover/plate and drained out the old fluid. Went to do a "dry" fitment with the Granatelli girdle/cover to see how it would mate up.
Well, the left side of the girdle sits flush on the housing, but the right (pass) side of the girdle is NOT flush with the diff. It sticks outwards (towards the gas tank).
I tried to "back off" that bolt on the right (pass) side of the new girdle as much as possible, but it still touches the inside of the diff - so it won't allow for a "flush" seal if I were to bolt it up to the housing. Not good.
Could I remove the "cap" (pass side) on the inside of the girdle so that it doesn't "touch" the inside of the differential ? If I did do that though, the girdle wouldn't provide the extra "bracing" that it was designed for - correct ?
The interference on the pasenger side is basically causing the girdle to not fit flush - hope I explained it well. Forgive my lack of proper terminology btw.
What should I do ? Should I try to remove that little cap (passenger side) on the inside of the girdle and then install the Granatelli piece (knowing that it won't offer any additional support/bracing) and live with it ?
Anyone else with a Granatelli girdle run into this problem ? I wasn't planning on using the supplied gasket, but even with the gasket tucked in between the housing and the girdle, it won't allow for enough space or "clearance" to provide for a proper "fit" on the passenger side.
Was planning on using Permatex Ultra Grey to make a gasket.
Some pictures:
New girdle sitting on the kitchen counter (problem bolt circled in red):
Picture of the inside of the girdle/diff cover (note fill and drain plugs, in blue - problem bolt circled in red again):
Removed the bolts of the factory diff cover except for the top one (left it loose) and allowed fluid to drain after cracking the cover (used gear oil smells sooo rancid - yuck!):
The guts of the differential - red circle shows the problem area:
Some pictures:
