  • 2005 - 2009 Specific Tech
driving a un-tuned auto with a gear
  • Thread starter Thread starter 91frppgt
  • Start date Start date Feb 15, 2009
9
91frppgt
56
  • Feb 15, 2009
I'm going to have to drive my car un-tuned with a gear for a while now, until i can get it tuned again. I have a 3.73, and the car is a auto. Besides the speedo reading to fast, should it hurt anything else?
AlloyGT
64
Colorado
Feb 15, 2009
  • Feb 15, 2009
The tune tells your auto at what mph to shift into each gear. If you can't use the tuner to tell your car what gears you have, I wouldn't drive it until you get a new tune.
Five Oh Brian
552
Pacific Northwest
Feb 15, 2009
  • Feb 15, 2009
Your upshifts and downshifts are going to be out of whack. I wouldn't drive it far with the tune not updated for the new gears, and definitely don't drive the car at wide open throttle with the shift points all messed up.
NastyStang113
1,567
Florida
Feb 15, 2009
  • Feb 15, 2009
TBrad
91
Dallas, Texas
Feb 15, 2009
  • Feb 15, 2009
If you had a manual tranny you'd be ok.
StonePony
218
  • Feb 16, 2009
BS - You will be just fine. The tranny shifts are based on RPM so the gear chang behind the transmission won't affect your cars shifting points negatively at all.
I ran 3.73 gears in my car for 6 months without changing the tune. The only negative effect was the extra 1800 miles it put on my odometer. Drive it as hard as you want there will be no issue.
AlloyGT
64
Colorado
Feb 16, 2009
  • Feb 16, 2009
Shift points in the tune are controlled by mph, not rpm.
StonePony
218
  • Feb 19, 2009
are you talking about the user defined settings or in the AdVantage III SCTsoftware used to create the tune?
I believe the only place you will see shift point in milesper hour (MPH) is when you are making adjustments as an end-user in the hand-held. Shift points are set in MPH in the tune.
Whichever you meant is no matter because driving the car with a gear change and no tune will hurt NOTHING but your odometer.
Five Oh Brian
552
Pacific Northwest
Feb 19, 2009
  • Feb 19, 2009
My tune was written to upshift at 6,400 rpm's at WOT. Otherwise, the tune is written with an algorithm that specifies upshifts at a particular MPH based on throttle position (assuming something less than WOT). So, upshifts are controlled by rpm's at WOT and controlled by mph & throttle position at partial throttle.
My tune was also written with new mph threshholds for downshifts so that it wouldn't downshift at too high an rpm after the gear change. Before doing so, the car would downshift at too high of speed and literally bounce the car off the rev limiter instantly. Had to have the tune altered for the lower speeds for each downshift with the shorter 4.10 gearing.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
M
93 5.0 Microsquirt with Stage 3 trickflow tuning issues
  • marxpreston11
  • Jun 22, 2026
  • Digital Self-tuning Forum
  • 2 3 4
2K
Digital Self-tuning Forum Wednesday at 4:45 PM
Qtrhrse23
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
Digital Self-tuning Forum Aug 11, 2026
roldy
R
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
