Dropping The Rear End
one_bad_5.0
New York
I herd someone talking about being able to drop the rear end a little bit so I can get my tailpipes out. Are these the supports I want to unbolt so I can avoid unbolting the springs, there are 2 of them and they are on the top of the rear end?:shrug:
Undo your the bottom bolt on the shock...it'll do the trick...Place a jack under the shock...undo the bolt and let drop slowly...You dont want to undo those upper control arms to do what you need...
Yup...make sure you have it jacked up high enuf to get some drop if your not on a lift...just go down slowly....watch your brakes lines as you drop so that you dont pull on them when the dif is lowered.
