Dropping weight = how much time?
Lifted07Sierra
9
Im helping my cousins husband turn his 96 GT into a fast lil machine. I already know all the performance parts to make them fast but one thing I never did to my saleen that I wanted to do was lighten it by ALOT
We have a goal of dropping the weight by 200lbs total. I was wondering whats a round about figure of -200lbs and how much it would knock of the 1/4 time?
Also anyone know how much a 96 gt weighs in stock form?
You'll gain around .1 seconds for every 100lbs of weight you remove. That's just an approximation. Be careful about removing weight from the rear half of the car without plenty of traction. A lot of the free and easy stuff to remove is in the back and will hurt your 60' time as the weight distribution gets worse.
You should gain about .2 seconds with 200lbs of weight reduction. For a car you want to drive on the street, I personally think it's easier to add power than remove weight. A car without AC, power steering, a dash and other interior parts isn't much fun to drive around, and you don't really gain that much! For a race car, it's different.
I had my 98 auto in the 3100 range though that included doing some reduction that most likely wouldn't do. remove spare, jack, board/carpet in trunk, rear seat (bracket is actually pretty heavy), the black thing above the rear seat (no idea of proper name haha) and this is where some will laugh--replace the driver seat with the one from the passenger side since driver seat has power and weighs quite a bit more.
bhuff does have a point about lack of weight over the tires can lead to a problem and worse 60's, especially if on street tires.
This is what we were thinking to drop the 200lbs
we got corbeau racing seats
removed spare tire
took out foaming underneath rear set probably a good 8lbs
doing a rear seat delete
UPR k member kit
UPR rear suspension pieces (uca, lca and what not)
remove front swaybar
Ill take a look at the list to figure out whatelse we can do without making the car look stripped.
I hear the UPR k member kit is worth a 65lb drop and the rear suspension over the stock parts is good for another 25lbs.
Anyone know if thats accurate or not?
Cheapest way to shave weight in the car.... Loose weight urself... :D I know most of us could afford to drop 20-30lbs.... Its free and will make you feel much better...
For real, the k member and batter relocation are some or ur best bets. Go all out and do a coil over set up and replace ur d/s with an alum one, big and little wheels/tires will go a long way.
Removing the front sway bar is great for drag racing. First, it removes some weight, 20+lbs, and from the front which is even better. It also allows for better weight transfer by allowing the front end to lift more easily.
I've seen good results from dropping weight, but it completely depends on WHERE you drop the weight from. Removing the spare tire, and everything else in the trunk makes the mustang a bit light and they don't really like to hook without good tires.
As a dramatic example, consider the first time I hit 12s with my 2.3. I made 11 passes, all in the low 13s. Everything from 13.0's to 13.4's, but I was having trouble with traction and was just a hair away from 12s. I got ready to leave the track, throwing about 150 lbs if stuff in the trunk, including my tools, an air compressor, full gas can and a bucket of spare parts. My friend encouraged me to make one more pass, with all the crap in the car. It was my first 12, a 12.97, the best of the 12 passes I made that night, just because the car hooked. I ran 1.5 mph slower, which was no big surprise, but got my 12 second run.
Moral of the story? Be careful where you drop the weight from if you are traction limited. Dropping weight from the front is GREAT, but removing it from the rear on a traction limited car will probably net the same ETs at a slightly higher mph.
