If it's P0190, Fuel Rail Pressure Sensor Circuit Malfunction:
The comprehensive component monitor (CCM) monitors the FPP sensor to the PCM for VREF voltage. The test fails when the VREF voltage from the PCM drops to a voltage less than a minimum calibrated value. The voltage should be between 4.0v and 6.0v.
Possible causes are listed as:
VREF open in harness. VREF open in sensor, VREF open in PCM.
I guess I'd start by checking the connection to the harness at the sensor on the fuel rail. Have you made any modifications to the fuel system?
