Dual Contour Fans
  • Thread starter Thread starter Jrock909
  • Start date Start date Jun 27, 2012
J
Jrock909
36
  • Jun 27, 2012
I'm just wondering if the contour fans have two speeds because they seem like they aren't keeping up with 100* heat, does the Mark VIII fan spin a lot faster than the contour fans and do you have to modify a lot of stuff for it to fit? I got the fans wired up in parallel on a switch so I can run manually or through the flexalite fan controller in the winter..... Maybe there's a way to kick those fans in high gear somehow??
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Jun 28, 2012
  • Jun 28, 2012
They are only 1 speed. They flow plenty of cfm, but suck alot of amps. The MarkVIII fan is by far the highest flowing. I am suprised that the contour fans are not keeping up. Is the rest of your system in good working
order?
Joe
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Jun 28, 2012
  • Jun 28, 2012
Do you have the fans wired through a relay? You don't just have them wired directly off a switch, right?
Mustang5L5
Mod Dude
Feb 18, 2001
43,376
18,123
224
Massachusetts
Jun 30, 2012
  • Jun 30, 2012
The fans should be sufficient.
I would question the state of the rest of the cooling system first.
Sent from my iPhone 4S using Tapatalk
HISSIN50
34
129
Jul 2, 2012
  • Jul 2, 2012
I would also ask for more info on how the system is wired up? Does each fan motor and/or speed have its own relay? Was sufficient wire gauge used?
Did the system ever function decently in 100* heat or is this the maiden test?
elarm1
1,428
652
154
N.Va
Jul 3, 2012
  • Jul 3, 2012
^^^^ I would like to know as well as I am about to wire up my MarkVIII fan
HISSIN50
34
129
Jul 3, 2012
  • Jul 3, 2012
What's your question or concern? The Mark VIII wiring is different but simple...........
elarm1
1,428
652
154
N.Va
Jul 3, 2012
  • Jul 3, 2012
^^A link on how to install one would be perfect!!
RacEoHolic330
4,014
1,698
203
Allentown, PA
Jul 3, 2012
  • Jul 3, 2012
If you just want to wire it up with a switch and relay so you can turn it on manually, you'll need an 75-80A relay for that fan. Wiring up the relay is easy. Plenty of diagrams on the net of how to wire an automotive relay.
HISSIN50
34
129
Jul 3, 2012
#10
  • Jul 3, 2012
  • #10
One method:
http://home.comcast.net/~smithmonte/Auto/MarkVIII_Fan.htm
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 5, 2012
#11
  • Jul 5, 2012
  • #11
If you don't have a high current alternator, you can forget about using the fan. The stock 65 amp alternator on 86-93 Mustangs isn't big enough to run the fan and the rest of the car. If you have a 94 or later Mustang, the stock 3g alternator should be fine if it is working correctly.
Switching a fan on and off manually is a bad idea. Too many guys have been distracted (hot girl kissing on their neck, too much to drink, dog tired and not thinking clearly) and cooked things because they forgot to flip the switch. An equal number have forgotten to turn the switch off for the same reasons and run down their battery.
The best fan controller available today is a DC Control unit. www.dccontrol.com. Cost is about $???. Be prepared to wait 4 weeks or more to receive your controller once you have sent in your payment. The controllers are custom made in small lots and lead times can stretch out.
Next best is a SPAL controller - $70-$90 See http://www.spalusa.com/fans/automated/accessories/fanpwm.html. eBay will have the controllers for the $70: do a Google search and see what you find.
At the bottom are the Hayden or Imperial controllers available through Advance Discount Auto Parts and AutoZone. The non adjustable one is about $30 ( Hayden 226206) and the adjustable one is about $60 (Hayden 226204). I recommend you do a Google search on Hayden and the part number for more info.
Do not use a simple on/off switch without using a relay. The current load can burn up the typical cheap automotive switch very quickly. The fan draws 30+amps and you need to use #10 wire on the fan power and ground wiring.
If you are good with electrical stuff (90% of the people here aren't), build your own controller. The numbers on the diagram (#86, #87, etc) refer to the numbers on the bottom of a typical automotive relay.
Note that the temp sensor in the diagram needs to match the thermostat in your engine. The preferred arrangement is to have it open about 5 degrees above the thermostat.
To allow the ignition switch to control the fan so that it does not run when the ignition is off, connect the relay contact #86 to the red/green wire on the ignition coil or to the red/yellow wire on the coolant level sensor.
If you are an experienced electronics tech or electrical engineer, email me and I will send you the prototype drawings of a fan controller that is similar in function to the DC Control unit. It is a build it, troubleshoot it yourself item. I will not build or troubleshoot units, so it is not suitable for anyone who isn't really good with electronics.
Alternate placement for a temp gauge sender or temp switch/temp sensor for an electric fan. Use the heater feed that comes off the intake manifold. Cut the rubber hose that connects the manifold water feed to the heater and splice in a tee adapter for the temp gauge sender. Be sure to use the same water feed line as the ECT sensor. That way you will get the most accurate temp readings.
Tee adapter info:
Make a pilgrimage to your local hardware or home supply center and get some copper pipe and a tee that fits the temp gauge sender. Solder two pieces of copper pipe onto a copper pipe tee with threads in the tee part. Find the correct brass fitting to match the temp sender threads to the tee fitting.
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
  • dan50
  • Jul 18, 2026
dan50
Electrical Contour fans wiring
  • JD1964
  • Dec 3, 2023
3K
Fox 5.0 Mustang Tech Jan 28, 2024
JD1964
T
SOLD 1979 Ford Mustang Cobra Hatchback 302 C4 Modified
  • toasterboy1
  • Nov 15, 2024
2K
Fox Body Mustangs For Sale (1979-93) Dec 20, 2025
toasterboy1
T
