dumb nitrous ?
tyler08
15
ok im ready to hook into the fuel supply. Would I be correct to assume it makes no diff. which fuel line I splice into. Also It appears that there is a protective hose overtop of the actual hose fuel is running through, is this correct also? Thanks for the help!
You'd need to tap into the feed line. The nitrous kit works by boosting fuel pressure, by essentially closing off the return line. No return line = no fuel for the solenoid. I believe you are correct about the line having a rubber hose on the outside. My 95 does, but I don't recall whether a Fox does, since I haven't had one in 10 years.
ok good to know about the schrader valve, how the .... did I miss that in the instructions? THis really simplifies things. THanks that just saved me alot of effort.:D
