OLDJUNK93 Member Mar 12, 2003 77 0 6 kansas Aug 1, 2004 #1 Aug 1, 2004 #1 this is a dumb question but where is the pcv valve located on a 93 5.0 and what all is involved in changing it? thanks in advance.
R ratrapp New Member Apr 24, 2004 510 0 0 buena vista,va Aug 1, 2004 #2 Aug 1, 2004 #2 it's located behind the intake on the backside.word of advice,get a motorcraft one as most aftermarket ones don't fit the rubber grommet very well.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 33 129 Aug 1, 2004 #3 Aug 1, 2004 #3 ratrapp is right. also renew the rubber grommet and the metal screen below it. all MC for 20 bucks and you can forget it for 2 years. if you search in here, you will find a ton of posts with little tips (i.e. Michael's tip about using a magnet to remove the screen, etc). good luck.
PNY PWR New Member Jul 23, 2004 522 0 0 Wichita, KS Aug 1, 2004 #4 Aug 1, 2004 #4 Not a dumb question at all, It's hid back there pretty good. If you don't have one you might get you a service manual, has alot of info on component locations, service procedures, and specifications.
