Dumb simpley question. How do to remove the Pully from the Power steering pump?
gruvee87vertgt
Oct 7, 2003
272
26
28
Chicago, Il
I know it's a simply question.
I tried a couple different ways and not getting anywhere.
also, where can I buy a chrome or polished one? thanx
or the bracket that lifts the ps pump higher to where the ac compressor is? thanx
A.S. is totally right on. And BE sure to use the install tool (that bolt they sometimes give you is not a good way to install the pulley).
FWIW, the ID on the pulley-hub can mushroom a bit from use; if yours looks pooey, it might be time fro a fresh pulley.
Good luck.
Yep, you need the remover tool. They are cheap enough now to just buy one. I also agree with the recommendation for the installer tool, as I have had the bolt they give you to install the new on break in mid install.
Most parts shops will r&r the pulley if you buy the pump there. But ask them first!
