I have a Duraspark distributor hooked to a GM ignition module. I know this set up requires a specific coil. What coil works? I bought a generic chrome coil from Jeg's and it didn't last long. It would idle for about 10 minutes then die. I tried another new Delco 1906 module and it was the same. Changed carbs, same thing. Put in the stock points coil and it ran good. Swaped back to the Jeg's coil, problem came back. I put the stock Ford coil circa 1971 and it ran good.
I let it idle for about 1/2 hour while I was charging the A/C, tracing heater A/C cable problems etc and it died again. The stock Ford points coil was hot. After it cooled down, it ran again.
I know I need a coil. Which coil should I get that will last?
I do not have an ignition resistor nor do I have an resistance wire going to the module.
Please let me know what coil you guys use that doesn't burn out or get hot and die.
Thanks.
Danford1
Thanks.
Danford1
