Durn Strut Nut
  • Thread starter Thread starter DTT92LX
  • Start date Start date Jun 29, 2005
DTT92LX
185
Downingtown, PA
Jun 29, 2005
  • Jun 29, 2005
So, after soaking in wd40 for a week, then banging with the BMFH, then hitting it with an impact wrench...what is the next step to breaking the original strut nuts loose? I really don't want to clamp anything on the strut shaft and scar it since I'm only installing cc plates...
Any other thoughts?
fox racer
577
Staten Island, NYC
Jun 29, 2005
  • Jun 29, 2005
honestly, if they are the stock struts, just spend some extra money and get tokicos or something... really get use out of the caster/camber plates.
alanw6
449
memphis, TN
Jun 29, 2005
  • Jun 29, 2005
If there's an easy way to remove that nut, I sure don't know it! It damn near killed me getting it removed when I did the springs/shocks/struts swap a little while back.
Subscribing to get a good answer for next time...
HISSIN50
34
129
Jun 29, 2005
  • Jun 29, 2005
I cant remember on a fox, but if you can see where the end of the compression in the strut is, you could use vice grips above that point (since it never passes through the cartidge seal). Have you tried a rubber clamping dealie (looks like a serpentine belt with a handle - I cant recall the name right now)?
Using an impact driver can help too.
Good luck.
darthcual
985
Arlington, TX
Jun 29, 2005
  • Jun 29, 2005
Ok heres how i broke mine loose. PB buster, and a little torch action. Just remember that PB buster is flammable but it burns off quickly. You will need two ppl. One applying the heat to the nut/stud area and one applying constant pressure with a wrench. Remember also that the wrench will get extremely hot so wear gloves or something. A cheater bar will help with the constant pressure or use the old locking two wrenches together trick. Hope that helps.
CManT1914
3,172
Killeen, Texas
Jun 29, 2005
  • Jun 29, 2005
I tried vice grips, I tried PB Blaster, I tried a BFH, I even tried using a screwdriver in that little slot then getting a wrench on it. I finally bought a big freaking 1/2" Craftsman impact wrench and it came off no problem. A 1/2" impact with a good swivel socket (needed that one for the freaking alternator pulley bolt) are invaluable tools for working on any car.
93 teal terror
971
62
69
Durham N.C.
Jun 29, 2005
  • Jun 29, 2005
I had to drill both mine off with carbid bits.....chewed right threw the mfer
HISSIN50
34
129
Jun 29, 2005
  • Jun 29, 2005
Oh yeah, one can head down to a shop and ask them to bust the nuts loose. Then cinch them up enough to safely get home and loosen/remove them.
Good luck.
ramjetlx
212
Honolulu, Hawaii
Jun 30, 2005
  • Jun 30, 2005
Remove the strut and put them into a vice grip located on a work bench. You have to put the skinny rod which is covered by the dust boot in between the vise or you will be turning the entire strut.(make sure you remove the dust boot before doing this) Use an impact gun or long bar on the end of a wrench to break it free. Took me 2 hours to figure this out and 5 minutes to do it.
nito88stang
2,012
Fullerton, California
Jun 30, 2005
#10
  • Jun 30, 2005
  • #10
Use a quality impact gun. Mine got it off pronto.
DTT92LX
185
Downingtown, PA
Jun 30, 2005
#11
  • Jun 30, 2005
  • #11
Thanks for the replies, gents. Spent another 1/2 hr with the impact wrench and it finally broke free. Guess another lesson learned on patience and persistence!
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
4.6 question for those in the know....
  • LILCBRA
  • Aug 30, 2024
2K
2005 - 2014 S-197 Mustang -General/Talk- Sep 4, 2024
Adieu
