I noticed the dust cover on the tranny that covers the hole where the cable goes into the tranny is missing. What kind of problems can this cause? If dust got in there could my clutch slip or squeek???
could it cause the clutch to squeek a bit??? I'm having this sort of squeek come out of the clutch when I release the clutch.... I'm hoping this is related
It only squeeks when just taking off in 1st gear. Just as the car starts moving and the clutch is just partially engaged it squeeks for a second. This only happens once in a while and that is the ONLY time it happens
Sounds to me like your clutch disc is worn out. When the rivets that hold the friction material to the metal disc start contacting the flywheel it makes a squeaking noise. Thats the sound of your flywheel getting groves in it. Dont take my word for it, get it checked out. If you dont take care of it real soon, you will need a new flywheel in addition to the clutch, pressure plate and throw out bearing.
