I think thats the 345 b/c it has the b cam and that one is rated at 345. Didn't you order the same one.5literstang said:u only got around 281 the the wheels with the GT40 crate motor? isn't that the 345hp motor? or do u have the 320hp one?
mto502 said:Very nice.
Do you know what the AF readings were prior to the tuning ? Did they do a baseline run or is that 1st run the base ?
If the motor is 345 at the crank shouldn't it be a bit more at the wheels or deoes it only crank that horsepower with specific parts?
EDIT : Yeah 281 is pretty close to the 345 at the crank anyway.
balderman said:The 1st run was the baseline. I am running 24lb injectors.. and I have the CAI on.. when they get 345 that is without the Air filter on, so you will lose some. I am going to go with 42lb injectors when I put on the Vortec.
Yes, you can use both your stock oil pan and stock valve covers on the GT40 motor. If you want to use the valve covers that they come with, you can easily do a Fox body conversion, and not have the headaches that we do. Keep in mind that you do lose cruise control when you do the swap.5literstang said:did u use ur stock oil pan and valve cover? i want to use the valve covers that they come with but i head that by TB will get in the way, insn't there a way around that? nad if there is please tell me, thanks
5literstang said:o i have 1 more question, what chip did u get and how much was everything there 2gther, cuz i'm also goin to laroccas to get mine done, thanks
5literstang said:i thought i wouldn't run into clearnece problems cuz i was looking at the pic on the motor and u can just tell that the valve covers would clear, i can't wait to get the motor in, lol, i don't live too far from larocca's anyway, about 25-30 minutes away, right after i graduate i should have 625 for the chip and dyno tune, thanks.
balderman said:FYI.. the 303B cam is extremely aggressive. the power band is from 3000-6000 rom.. when cruizing between 2000-3000 the car gets the herky-jerky's.. it is very slight but you can feel it.. almost feels like a hesitation.. but I was assured by FMS tech support that it is normal and can not be tuned out with a chip... I am use to it now.. but new passengers in the car can feel it...
